can not reach dmz
Omar Abdelhalim
Dear All,
I have the following topology:
ASA Config as following:
MyASA(config)# sh run
: Saved
ASA Version 8.0(2)
hostname MyASA
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 196.219.219.1 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.10.65 255.255.255.0
interface Ethernet0/2
nameif dmz
security-level 70
ip address 10.101.0.17 255.255.255.240
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
boot config disk0:/.private/startup-config
ftp mode passive
access-list inside_acl extended permit icmp any host 196.219.219.3
access-list inside_acl extended permit tcp any host 196.219.219.3 eq https
access-list inside_acl extended permit tcp any host 196.219.219.5 eq www
access-list inside_acl extended permit icmp any host 196.219.219.5
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any echo-reply outside
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 196.219.219.3 192.168.10.187 netmask 255.255.255.255
static (dmz,outside) 196.219.219.5 10.101.0.18 netmask 255.255.255.255
static (dmz,inside) 192.168.10.50 10.101.0.18 netmask 255.255.255.255
access-group inside_acl in interface outside
route outside 41.178.25.0 255.255.255.0 196.219.219.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet 192.168.10.0 255.255.255.0 inside
telnet timeout 15
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:a41e50d1e8b70379a3f1a8b47a3ab160
: end
and router Config as following if you need:
R1#sh run
Building configuration...
Current configuration : 1169 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
ip domain name lab.local
archive
log config
  hidekeys
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
no ip address
shutdown
duplex full
speed 1000
media-type gbic
negotiation auto
interface FastEthernet1/0
ip address 196.219.219.2 255.255.255.248
duplex auto
speed auto
interface FastEthernet1/1
ip address 41.178.25.1 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
logging alarm informational
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
from ASA I can ping all these PCs (can be reached), C2 is a web server can be accessed from the outside by the natted IP"196.219.219.5". but, the inside PC can not access, or ping this server by the natted IP "192.168.10.50".. why?
Omar Mahmoud
Hi Omar,
Please go through the link below:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aad.shtml
Create a static translation between the entire inside network and the DMZ that does not actually translate inside addresses.
static (inside,dmz) 10.1.6.0 10.1.6.0 netmask 255.255.255.0
Create a static translation to allow one inside host access to the DMZ without actually translating the address of the host.
static (inside,dmz) 10.1.6.100 10.1.6.100 255.255.255.255
    If you have a public address on the inside network, and you want the inside hosts to go out to the outside without translation, you can disable NAT. You also need to change the static command.
    Using the  the nat command changes as this output shows:
    nat (inside) 0 175.1.1.0 255.255.255.0
    Use these commands if you use ACLs in PIX software versions 5.0.1 and later:
    access-list 103 permit ip 175.1.1.0 255.255.255.0 any nat (inside) 0 access-list 103
    This command disables NAT for the 175.1.1.0 network. The static command for the web server changes as this output shows:
    static (inside, outside) 175.1.1.254 175.1.1.254
    This command defines the conduit for the web server.
    conduit permit tcp host 175.1.1.254 eq www any
    access-list 102 permit tcp any host 175.1.1.254 eq www access-group 102 in interface outside
    Please rate helpful posts
    Thanveer
    "Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
