04-14-2013 07:14 AM - edited 03-11-2019 06:28 PM
Hello, everyone,
I ran into a very strange icmp ping issue that I could not seem to undersatand, hope someone can provide a troubleshooting tip on this. The network has been working fine other than the issue listed below, L2L VPN works
fine and all three data centers can access each other via L2L VPN.
I have three ASA5510:
asa10
Inside IP: 10.10.10.254
L2LVPN: asa10TOasa20, asa10TOasa30
asa20
Inside IP: 10.20.20.254
asa30
Inside IP: 10.30.30.254
Other than, global IP addresses, subnet IP addresses, the run configs are pretty much the same.
Problems:
From network 10.10.10.0, can ping 10.10.10.254, 10.20.20.254
Can't ping 10.30.30.254
From network 10.20.20.0, can ping 10.10.10.254, 10.20.20.254
From network 10.30.30.0, can ping 10.20.20.254, 10.30.30.254
Can't ping 10.10.10.254,
Please help by providing your insights or troubleshooting tips. My customer would not allow me to post configs.
Thanks.
Solved! Go to Solution.
04-14-2013 10:14 AM
Assuming that u have the vpn config in place, pls ensure that you have the following configured in the config mode on asa30
man inside
Where "inside" is the name of the interface u r trying to ping.
Sent from Cisco Technical Support Android App
04-14-2013 07:22 AM
Hi Bin,
I have spent hours trying to resolve it first time...
In my case the issue was with dynamic nat. When you use object definition for PAT, please use range (excluding ip of the firewall) as opposed to subnet.
Let me know if that helps.
Kind Regards,
Paul Preston
Proxar IT Ltd. Registered in England and Wales: 6744401- VAT: 942985479
Tubs Hill House, London Road, Sevenoaks, Kent, TN13 1BL
Tel: (+44) 0844 809 4335
Fax: (+44) 01732 468 574
Mob: (+44) 077 9509 3450
Web: www.proxar.co.uk
Email: paul.preston@proxar.co.uk
04-14-2013 09:41 AM
Hello Bin,
add the route-lookup to the nat statement,
without configs we are blind
04-14-2013 10:14 AM
man inside
04-14-2013 05:43 PM
Thanks. "man inside" did work.
But do you have to do this for L2L VPN? I mean is "man inside" a required configuration?
Thanks.
04-14-2013 07:34 PM
Bin, it is only required if u have management traffic directed towards interface over the vpn tunnel.
Sim.
Please mark resolved questions as "Answered"
