10-16-2012 10:44 AM - edited 03-11-2019 05:10 PM
I have recently bought a Cisco pix 515E firewall primarily to learn from. I have had watchguard firewalls in the past.
Powers up ok, link lights up etc... but PC set to DHCP aquires only 169.154.x.x addresses ??
Cannot connect, cannot run reset command.
Is there a way to reset the device ? I have read the manuals and reset password seems to be an option but I dont
know the version of software running ...
please can someone help me just to get started ...
many thanks
Simon
Solved! Go to Solution.
10-16-2012 12:03 PM
That IP means you did not recieve a DHCP address. Console into the PIX and see if you can get into enable mode, then you can set that up.
10-16-2012 11:08 AM
they should have given you a paper with the FOS version installed and so you should do a password reset provided there is already one, by default password is null. Try to connect with console cable and you'll see if you need to do a password reset otherwise then post the show run here.
Regards.
Alain
10-16-2012 12:03 PM
