Cisco ASA 5505, IPv6 and TunnelBroker
Jose Pena
Hello everybody,
this is the configuration sample that Tunnelbroker gives to IOS router (not ASA )
configure terminal
interface Tunnel0
description Hurricane Electric IPv6 Tunnel Broker
no ip address
ipv6 enable
ipv6 address xx:xx:xx:xx:::2/64
tunnel source MY.WAN.IP..248
tunnel destination TUNNEL.BROERKIP.104.74
tunnel mode ipv6ip
ipv6 route ::/0 Tunnel0
end
The questions is how to put that into Cisco ASA 5505 with 8.2(1) OS version.
If anyone has be done this one, a good sample will be really appreciated.
Have a nice day/night.
Jos P.
easy: You just don't do that ... These tunnels are not supported on the ASA. As a workaround you could place an IOS-router in front of your ASA or into a DMZ. Or even better, ask your ISP for native IPv6. But for me, asking the ISP did not help in the last five years ...
regards, Karsten
5 Replies 5
regards, Karsten
I have a tunnel setup with Hurricane Electric.   I have an ASA that is in front of an IOS router. Should the ASA pass this tunnel traffic ?
Network looks like....
Internet <->  ASA <->  L3 Switch (IOS15) <-> Windows Boxes
I cannot get the tunnel up.
Do I need to setup any ACL's or static's on the ASA to pass the traffic from the IPv6 provider to the L3 Switch ?
You need to make sure that IP/41 can pass between the two tunnel-endpoints.
tglen:
Can you explain how to create a tunnel with TunnelBroker? I read about it here and the ASA can do only encrypted tunnels and tunnelbroker doesn't support encrypted tunnels. I will appreciate any information.
Have a nice day.
he is talking about transporting a tunnel through the ASA.
