03-18-2015 08:07 PM - edited 03-11-2019 10:39 PM
Hello all,
I'm having trouble setting up a second vlan to route to the internet. I have a Cisco ASA 5505 connected to my ISP(OUTSIDE) and a Cisco 881w (INSIDE) router in the back of my firewall. My vlan 10 with the network 192.168.5.1 255.255.255.0 works with pat, however vlan 15 that is on my 881w router does not route to the internet at all. I can only ping from 192.168.15.15 network to 192.168.5.1 I would like some advice on how can I make this set up work. Attached with this discussion is a picture of my topology.
Thanks in advance.
here are the show runs:
Cisco ASA 5505 show run:
ASA Version 8.3(1)
names
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan5
mac-address xxxx.xxxx.xxxx
nameif OUTSIDE
security-level 0
ip address dhcp setroute
interface Vlan10
nameif INSIDE
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 5
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
object network INTERNAL_LAN
subnet 192.168.5.0 255.255.255.0
object network PRIVATE_LAN_192
subnet 192.168.15.0 255.255.255.224
description PRIVATE_LAN_192
access-list INSIDE_access_in extended permit ip any any
access-list INSIDE_access_in extended deny ip any any
access-list OUTSIDE_access_in extended permit ip any any
access-list OUTSIDE_access_in extended deny ip any any
pager lines 24
logging enable
mtu OUTSIDE 1500
mtu INSIDE 1500
ip verify reverse-path interface OUTSIDE
ip verify reverse-path interface INSIDE
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (INSIDE,OUTSIDE) dynamic interface
access-group OUTSIDE_access_in in interface OUTSIDE
access-group INSIDE_access_in in interface INSIDE
route INSIDE 192.168.15.0 255.255.255.224 192.168.5.2 1
dynamic-access-policy-record DfltAccessPolicy
http server enable
dhcpd dns 8.8.8.8 75.75.76.76
dhcpd address 192.168.5.10-192.168.5.100 INSIDE
dhcpd enable INSIDE
Router 881w show run:
Current configuration : 4912 bytes
version 12.4
no ip source-route
ip dhcp excluded-address 192.168.15.1 192.168.15.10
ip dhcp pool PRIVATE_LAN
network 192.168.15.0 255.255.255.224
interface FastEthernet0
switchport trunk allowed vlan 1,15,1002-1005
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 192.168.5.2 255.255.255.0
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
no ip address
interface Vlan15
ip address 192.168.15.1 255.255.255.224
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
no ip http server
ip http authentication local
ip http secure-server
03-18-2015 09:46 PM
Whilst I look through your config, can you give a little more info about the cable modem? Does it contain any configuration?
03-19-2015 06:51 AM
The cable modem does not have any configuration. I cant add any to it. Its a cisco dpc3008. From vlan 10 i have no problem to get to the internet with the above configuration. My problem is just vlan 15.
03-20-2015 10:26 AM
Can you post the output of a pack-tracer from inside (vlan 15) to outside.
03-20-2015 11:38 AM
Can you post the output of the command "show nat"
03-19-2015 06:53 AM
I've added a pc to vlan 10 and it routes to the internet.
12-09-2015 11:44 AM
Hi Heber,
I have a similar network at home:
Motorola Modem>ASA5510>881W>3780>3780.
Did you ever resolve your issue?
John T
12-14-2015 06:58 AM
Yes I did, are you having a problem?
