08-27-2015 10:58 PM - edited 03-11-2019 11:30 PM
Is it possible to create dhcp-scope over /24, like /16 or /8 or superscope etc?
br.
OLLI
Solved! Go to Solution.
08-28-2015 02:43 PM
Table 1-1 shows the licensing requirements for DHCP.
Table 1-1 Licensing Requirements
For the ASA 5505, the maximum number of DHCP client addresses varies depending on the license:
Please remember to select a correct answer and rate helpful posts
08-28-2015 02:41 PM
As far as I know the ASA is limited to 256 addresses...ie. /24 subnet.
08-28-2015 02:43 PM
