Welcome to Cisco Firewalls Community
33976
Beginner
Cisco ASA 5520 CPU Usage is ranging 87%- 93%
what is the command?
when I entered the show logging, this result shows:
INTFW(config)# show logging
Syslog logging: enabled
    Facility: 16
    Timestamp logging: disabled
    Standby logging: disabled
    Debug-trace logging: disabled
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging: disabled
    Trap logging: disabled
    History logging: disabled
    Device ID: disabled
    Mail logging: disabled
    ASDM logging: level informational, 2153425037 messages logged
I think this is not the one you are asking.
I see you have asdm, you can go to monitoring--->Logging and grab the logs from there, or do, logging buffered 6 and then show log.
Mike
Mike
Beginner
oh yes we are, and I don't even know how to use it yet.
here is the result, I just did it on CLI instead.
    Facility: 16
    Buffer logging: level informational, 189920 messages logged
    Device ID: disabled
    ASDM logging: level informational, 2163529896 messages logged
12.84/3306)
<134>:%ASA-session-6-302013: Built outboection 3204397854 for outside:156.99.135.115/445 (156.99.135.115/445) to inside:x.x.211.122/4070 (x.x.211.122/4070)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204397855 for outside:48.29.51.119/445 (48.29.51.119/445) to inside:x.x.212.168/4095 (x.x.212.168/4095)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204397856 for outside:153.29.17.47/445 (153.29.17.47/445) to inside:x.x.215.62/4600 (x.x.215.62/4600)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204397857 for outside:93.96.181.119/445 (93.96.181.119/445) to inside:x.x.216.128/4724 (x.x.216.128/4724)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204397858 for outside:142.117.190.105/445 (142.117.190.105/445) to inside:x.x.211.153/4731 (12.230.211.15session-6-302014: Teardown TCP connection 3204241463 for outside:148.18.251.18/42014: Teardown TCP connection 3204241489 for outside:152.34.30.80/445 to inside:x.x.212.234/3528 duration 0:00:30 bytes 0 SYN Timeout
<134>:%ASA-session-6-302014: Teardown TCP connection 3204241490 fort
<134>:%ASA-session-6-302014: Teardown TCP connection 3204242978 for outside:133.97.126.73/445 to inside:x.x.211.137/3009 duration 0:00:30 bytes 0 SYN Timeout
<134>:%ASA-session-6-302014: Tear12.93/3984)
nection 3204242979 for outside:184.32.145.19/445 to inside:x.x.212 for outside:172.99.172.115/445 (172.99.172.115/445) to inside:x.x.218.192/3260 (x.x.218.192/3260)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204399383 for outside:94.122.223.124/445 (94.122.223.124/445) to inside:x.x.216.127/4647 (x.x.216.127/4647)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204399384 for outside:76.58.162.61/445 (76.58.162.61/445) to inside:x.x.212.93/3985 (x.x.212.93/3985)
<134>:%ASA-see:12.230.212.241/1908 duration 0:00:30 bytes 0 SYN Timeout
<134>:%ASA-session-6-62 for outside:63.68.184.29/445 (63.68.184.29/445) to inside:x.x.215.87/1840 outbound UDP connection 3204405586 for outside:168.126.63.1/53 (168.126.63.1/53) to inside:x.x.217.211/4038 (x.x.217.211/4038)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204405611 for outside:136.102.38.80/445 (136.1012.230.211.180/1197)
<134>:%ASA-session-6-302013: Built outbound TCP connection 2848 duration 0:00:30 bytes 0 SYN Timeout
<134>:%ASA-session-6-302014: Teardown 0:30 bytes 0 SYN Timeout
<134>:%ASA-session-6-302014: Teardown TCP connection 32 0 SYN Timeout
<134>:%ASA-session-6-302014: Teardown TCP connection 3204249238 fside:x.x.211.180/1199 (x.x.211.180/1199)
<134>:%ASA-session-6-302013: Builimeout
<134>:%ASA-session-6-302014: Teardown TCP connection 3204249288 for outsi:%ASA-session-6-302014: Teardown TCP connection 3204249314 for outside:42.29.214sion-6-302014: Teardown TCP connection 3204249340 for outside:181.20.123.79/445  to inside:x.x.211.160/1261 (x.x.211.160/1261)
<134>:%ASA-session-6-302013nection 3204405719 for outside:159.113.13.89/445 (159.113.13.89/445) to inside:10.211.20/4022)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204402014: Teardown TCP connection 3204249371 for outside:80.49.124.112/445 to inside TCP connection 3204249397 for outside:45.93.39.15/445 to inside:x.x.215.48/3n 3204249423/445) to inside:x.x.216.91/2482 (x.x.216.91/2482)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204408253 for outside:152.54.105.115/445 (152.54.105.115/445) to inside:x.x.211.150/3239 (x.x.211.150/3239)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204408254 for outside:64.95.156.117/445 (64.95.156.117/445) to inside:x.x.218.225/4888 (x.x.218.225/4888)
<134>:%ASA-session-6-302013: Built outbound TCP connection 3204408255 for outside:59.51.64.61/445 (59.51.64.61/445) to inside:x.x.211.150/3240 (x.x.211.150/3240)
INTFW(config)# ion-6-302013: Built outbound TCP connection 3204408256 for outside:105.52.141.20/445 (1
Mark
Mark,
Do you know the following Addresses ?
152.54.105.115
64.95.156.117
59.51.64.61
What I am seeing so far is just a lot of tcp connections that are not that normal. And most of them end up on SYN timeout. Can you tell me if outbound TCP traffic (445) for file sharing (Not FTP, FTP goes over 21) is normal? We can set some policies on the firewall to limit the amount of oubound embryonic connections.
Let me know.
Mike
Mike
Beginner
I don't know those addresses, they're from outside, the first 2 IPs are from US & the last one came from China I think. can you help me setting up policies?
Mark
Uhm, Sure why not.
First, if not 445 traffic should be going out, block that traffic outbound. Second, we can go ahead and set the policy for half-open sessions on that specific port.
Here,
Access-list MPF permit tcp any any eq 445
class-map MPF
match access-list MPF
Policy-map global_policy
class MPF
  set connection per-client-embryonic-max 10
If no TCP 445 traffic should be going outbound, do the following
access-list inside deny tcp any any eq 445
access-list inside permit ip any any
access-group inside in interface inside.
Mike
Mike
Mike
Beginner
I sent the access-list of our ASA on your private message before I execute this. is it safe to do this, will it not affect the production?
Beginner
It can't be done. I entered the commands, after that the CPU usage drops so fast. I didn't realized that all the distribution and access switches lost their connections. I removed the commands, now our internet connections fluctuates and the CPU usage of this ASA is now 99%. I don't know what to do with this.
Enthusiast
check which IP do more traffic
#sh local-host | i host|count|maximum
and after check the IP detailed for example:
#sh local-host 10.10.10.10 all detail connection
Enthusiast
do you have an IPS module ?
Class-map: global-class
       IPS: card status Unresponsive, mode inline fail-open, sensor vs0
         packet input 197451550328, packet output 197459152624, drop 3901726, reset-drop 395164
#sh module
Enthusiast
check the resource usage with the
#show resource usage
So, we know there that it is in fact the traffic hitting the inside interface. Now, I saw something really alarming on one of the access lists that is there and I think that is when the problem of internet connection issue came in. Did you use the commads I gave you or did you use ASDM.
A policy needs to be set while you troubleshoot the inside network to mitigate the impact on the ASA.
Let me know when you have time.
Mike
Mike
Beginner
Hey Mike,
Sorry for the late reply. We' were so busy because of that CPU usage issue. Well, we found out that it was actually a virus who makes our CPU usage very high. After scanning some PCs on our machine in production, CPU usage suddenly drops to less than 20%. It was wierd but, I'll let you know the details, after we figured out how to totally eliminate the worm actually. Thanks for your help & good luck on your CCIE exam.
Mark
Beginner
Roberto,
Thanks for the post & sorry I wasn't able to reply. It seems we are on the right track now, but if ever there's an issue again, I'll let you know as well.
Thanks again,
Mark
