Hello everybody
we have 2 firewalls in our network 1 5550 and one 5585-x and the problem is we can not monitor the chassis and cpu temprature via snmp.
after a lot of search i have found a cisco bug : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur55645
that said if you want to monitor the temperature of the cisco firewalls use cli instead snmp !!!!!!!!
can you please explain that if there is any solution for monitoring cisco firewalls temp via snmp or is that impossible at all?
Thanks in advance
