Welcome to Cisco Firewalls Community
193
Beginner
Cisco ASA 5555-X logging
hi!
I have probably very simple question but i can't find the information i need.
So here it is: we have asa5555-x with created context for ISP and admin context. ISP's context has inside and outside interfaces. Both has public ips assigned to it. Admin context has managment interface configured to access ASA from the inside network. Now i need to send logs from ISP's context to the host inside our network but because of both interfaces in ISP context are with public IPs how should i do that?
Tere are no routes from ISP context to our private network, only from managment interface, but it is not in ISP context.
So when i try to put the lines
logging host interface_name ip-connector there is no option to send logs from managment interface. Only inside and outside which has no routes to private netowk.
What should i do?
1 REPLY 1
VIP Advisor
Re: Cisco ASA 5555-X logging
If your Syslog server not in the network IP range, First you need to make arrangments routing to be fixed to reach the Syslog server.
This can be done using or adding another same IP range in the interface, and only allow Syslog server and rest deny.
BB
*** Rate All Helpful Responses ***
