ā05-07-2013 04:06 AM - edited ā03-11-2019 06:39 PM
Hi Everyone ,
We are deploying the Cisco ASA 5585 in transparent mode with multiple contexts, the port-channel was configured to connect to the core switches using dot1q trunk.
We are experiencing an issue which is the core switches are configured loop guard globally, therefore the port-channel connected to the firewalls will be put into inconsistent state when the failover happen, and the two firewalls' failover can not fulfill the failover at last.
I have two queries below.
1. Does the firewall allow the BPDU passing through when it is in standby mode, for example, secondary firewall is active for group 2 and standby for group 1. does the secondary firewall block the BPDU from the valns under group1 ?
2. Can we disable the loop guard feature on the switch port-channel or is there anyother way to solve this issue ?
Best Regards,
Veon
ā05-07-2013 06:43 AM
Anyone can help ?
ā11-19-2013 03:55 AM
Hello Veon,
I can only reply to your first question : An ASA does not forward any traffic on the interfaces/vlan where it acts as standby, so it does not forward the BPDU on these vlans.
I have the same issue as you, so if you have found a solution, I would be happy if you can share it.
benjamin
ā11-19-2013 08:52 PM
as far I saw so far the Loop Guard feature is global. Depending on your switch platform/IOS version, you can try to use the Bridge Assurance feature as an alternative to STP LG. STP BA has to be enabled on a global level as well, but you afterwards you have to activate it on an interface level.
Please use the following link in order to have details about STP BA.
search for "Understanding Bridge Assurance"
Best Regards
Heiko
