Welcome to Firewalls
703
Beginner
Cisco ASA 7.2(2) and undersize packet
I have one Cisco Catalyst 2960 connected to ASA 5520 as Trunk. The version on ASA is 7.2(2).
The port on the 2960 connected to ASA is reporting lost of undersize packet.
Is there any problem with this on version 7.2(2) or shuld I continue search for the problem.
Best Regards
Magnus
1 ACCEPTED SOLUTION
Re: Cisco ASA 7.2(2) and undersize packet
Undersize packet is not a problem. Cisco devices keep a count of how many
undersize packets they have received but will still pass them through.
Mostly, undersize packets are generated due to driver issues. If you think
that it is still a problem, upgrade the code on the firewall.
Hope this helps.
NT
Hope this helps.
NT
Beginner
Okey!
Thanks!
Best Regards
Magnus
Participant
Please check the following DDTS/Bug if your Catalyst 2960 is working before 12.2(37)SE.
CSCsh17651
3560 connected via dot1q cause undersize counters to incress
Shin
Ask the Expert- MPLS troubleshooting
