Cisco ASA 8.4.2 acl hitcount issue
CSCO11520436
I have some peculiar issue that my acl hit count is not getting increased. not bale to ping the public ip's
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
access-group inside_access_in in interface inside
icmp permit any inside
icmp permit any outside
im able to ping my inside interface but not able to ping internet. from asa im able to ping internet
my packet tracer output below.
packet-tracer input inside icmp 10.20.90.1 7 7 8.8.8.8 detailed
ASA# packet-tracer input inside icmp 10.20.90.1 7 7 8.8.8.8 $
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         Outside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0x6e1ef600, priority=500, domain=permit, deny=true
        hits=171641, user_data=0x8, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
        input_ifc=inside, output_ifc=any
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: Outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ASA#
my nat is like below
object network obj_any
subnet 0.0.0.0 0.0.0.0
nat (inside,outside) dynamic interface
Any suggestion really appreciated.
Karthik S
Julio Carvajal
Add the following
fixup protocol ICMP
If this does not make the difference do the following:
1) Check the Ip address on your PC, make sure the ASA is the default gateway?
2) Ping the ISP address ( The default gateway of the ASA)
3) Share the complete output of show run nat
Let me know the result
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
