Cisco ASA acl on inbound and outbound
kimyinwuCCNA
Hi Community,
I have a Cisco ASA5510 firewall, and I have configured it with ACL in both inbound and outbound interfaces (for more security).
How will this behave with inspections? Will the package be inspected twice? Will problems occour?
ASA fw is running ASA8.2
(inside network) --> (inbound acl) [inside intf-FW-outside intf] -> (outbound acl) --> (internet)
KimYin Wu
CCNA
The ACL check and inspection are done once,  If the traffic is allowed the connection is entered into the State table.  From this point on, traffic from that particular flow is checked against the state table.
if a traffic flow is permitted by the first ACL it encounters no further ACLs are checked, only the state table is checked.
Please remember to rate and select a correct answer
Please remember to select a correct answer and rate helpful posts
If there is interfaces called LAN and WAN and for example WAN interface has an INBOUND ACL and LAN interface has an OUTBOUND ACL then the packet will be checked against both of these ACL
Example from my ASA
access-group LAN-OUT out interface LAN
access-group WAN-IN in interface WAN
access-list WAN-IN extended permit ip host 3.3.3.3 any
access-list LAN-OUT extended deny ip host 3.3.3.3 any
access-list LAN-OUT extended permit ip any any
ASA# packet-tracer input WAN tcp 3.3.3.3 12345 x.x.x.x 22
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
object network ROUTER
nat (LAN,WAN) static x.x.x.x
Additional Information:
NAT divert to egress interface LAN
Untranslate x.x.x.x/22 to 10.0.10.1/22
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 5
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: ACCESS-LIST
Subtype: log
Result: DROP
Config:
Result:
input-interface: WAN
input-status: up
input-line-status: up
output-interface: LAN
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
- Jouni
