Whenever my ASA boots, it needs more then one attempt to load the IOS. It starts doing it over and over again (mostly 4 or 5 times) At the end, it succeeds and I have a prompt. Doing some research, this does not look oke is it?
ciscoasa# sh boot
BOOT variable =
Current BOOT variable =
CONFIG_FILE variable =
Current CONFIG_FILE variable =
Some add information:
ciscoasa# sh ver
Cisco Adaptive Security Appliance Software Version 8.4(4)
Device Manager Version 6.4(9)
Compiled on Mon 21-May-12 10:48 by builders
System image file is "disk0:/asa844-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 24 mins 13 secs
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xfff00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.06
Number of accelerators: 1
0: Int: Internal-Data0/0 : address is 0022.552a.ae03, irq 11
1: Ext: Ethernet0/0 : address is 0022.552a.adfb, irq 255
2: Ext: Ethernet0/1 : address is 0022.552a.adfc, irq 255
3: Ext: Ethernet0/2 : address is 0022.552a.adfd, irq 255
4: Ext: Ethernet0/3 : address is 0022.552a.adfe, irq 255
5: Ext: Ethernet0/4 : address is 0022.552a.adff, irq 255
6: Ext: Ethernet0/5 : address is 0022.552a.ae00, irq 255
7: Ext: Ethernet0/6 : address is 0022.552a.ae01, irq 255
8: Ext: Ethernet0/7 : address is 0022.552a.ae02, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces : 8 perpetual
VLANs : 3 DMZ Restricted
Dual ISPs : Disabled perpetual
VLAN Trunk Ports : 0 perpetual
Inside Hosts : 10 perpetual
Failover : Disabled perpetual
VPN-DES : Enabled perpetual
VPN-3DES-AES : Disabled perpetual
AnyConnect Premium Peers : 2 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 10 perpetual
Total VPN Peers : 12 perpetual
Shared License : Disabled perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
UC Phone Proxy Sessions : 2 perpetual
Total UC Proxy Sessions : 2 perpetual
Botnet Traffic Filter : Disabled perpetual
Intercompany Media Engine : Disabled perpetual
This platform has a Base license.
Running Permanent Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Configuration register is 0x1
Configuration last modified by enable_15 at 13:01:05.779 UTC Sun Jul 22 2012
ciscoasa# sh run
ASA Version 8.4(4)
hostname ciscoasa
enable password Nd encrypted
passwd encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
client-update enable
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:7607625bb72b86ef5e8aa2d2bf8b26a1
Duplicate posts.
Hi Bro
This is a problem. Can you paste the following output here?
FW1# show flash
FW1# dir
Hi!
Here it is:
ciscoasa# sh flash
--#-- --length-- -----date/time------ path
81 25214976 Jul 22 2012 12:26:00 asa844-k8.bin
82 18927088 Jul 22 2012 12:26:32 asdm-649.bin
2 2048 Jul 22 2012 12:30:44 log
5 2048 Jul 22 2012 12:31:02 crypto_archive
75 0 Jul 22 2012 12:31:04 nat_ident_migrate
9 2048 Jul 22 2012 12:31:08 coredumpinfo
10 59 Jul 22 2012 12:31:08 coredumpinfo/coredump.cfg
127004672 bytes total (82567168 bytes free)
ciscoasa# dir
Directory of disk0:/
81 -rwx 25214976 12:26:00 Jul 22 2012 asa844-k8.bin
82 -rwx 18927088 12:26:32 Jul 22 2012 asdm-649.bin
2 drwx 2048 12:30:44 Jul 22 2012 log
5 drwx 2048 12:31:02 Jul 22 2012 crypto_archive
75 -rwx 0 12:31:04 Jul 22 2012 nat_ident_migrate
9 drwx 2048 12:31:08 Jul 22 2012 coredumpinfo
Hi Bro
Perhaps, there's something wrong with your FLASH hardware. However, before we conclude anything, could you do the following steps. This may help to identify the root cause.
Step 1 : remove all configuration from your FW and reboot the unit.
Step 2 : format disk0:
Step 3 : re-download the FW image file again asa844-1-k8.bin (25214976 bytes) and reboot the unit.
Note: The ASDM can come in later.
Step 4: put in this command "boot system flash:/asa844-1-k8.bin", save the config and reboot the unit.
Step 5: place back all your present configuration, and reboot the unit.
The above steps will narrow down if it's the present software image or the configuration or the flash hardware that's the root cause. Let me know how it goes :-)
P/S: If you think this comment is useful, please do rate them nicely :-)
Could you please check the following log at bootup. Eventually it loads, but before that it does several attempts:
Loading...
IO memory blocks requested from bigphys 32bit: 9672
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)11 04/30/08 15:45:41.19
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 01 00 1022 2080 Host Bridge
00 01 02 1022 2082 Chipset En/Decrypt 11
00 0C 00 1148 4320 Ethernet 11
00 0D 00 177D 0003 Network En/Decrypt 10
00 0F 00 1022 2090 ISA Bridge
00 0F 02 1022 2092 IDE Controller
00 0F 03 1022 2093 Audio 10
00 0F 04 1022 2094 Serial Bus 9
00 0F 05 1022 2095 Serial Bus 9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)11) #4: Thu May 1 14:50:05 PDT 2008
Platform ASA5505
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Launching BootLoader...
Boot configuration file contains 1 entry.
Loading disk0:/asa844-k8.bin... Booting...
Platform ASA5505
Loading...
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Platform ASA5505
Platform ASA5505
Loading...
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Platform ASA5505
Platform ASA5505
Loading...
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Platform ASA5505
Platform ASA5505
Loading...
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
Starting check/repair pass.
Starting verification pass.
/dev/hda1: 88 files, 12456/62014 clusters
dosfsck(/dev/hda1) returned 0
Processor memory 104857600, Reserved memory: 41943040
Total SSMs found: 0
Total NICs found: 10
88E6095 rev 2 Gigabit Ethernet @ index 09 MAC: 0000.0003.0002
88E6095 rev 2 Ethernet @ index 08 MAC: 0022.552a.ae02
88E6095 rev 2 Ethernet @ index 07 MAC: 0022.552a.ae01
88E6095 rev 2 Ethernet @ index 06 MAC: 0022.552a.ae00
88E6095 rev 2 Ethernet @ index 05 MAC: 0022.552a.adff
88E6095 rev 2 Ethernet @ index 04 MAC: 0022.552a.adfe
88E6095 rev 2 Ethernet @ index 03 MAC: 0022.552a.adfd
88E6095 rev 2 Ethernet @ index 02 MAC: 0022.552a.adfc
88E6095 rev 2 Ethernet @ index 01 MAC: 0022.552a.adfb
y88acs06 rev16 Gigabit Ethernet @ index 00 MAC: 0022.552a.ae03
Verify the activation-key, it might take a while...
Failed to retrieve permanent activation key.
****************************** Warning *******************************
This product contains cryptographic features and is
subject to United States and local country laws
governing, import, export, transfer, and use.
Delivery of Cisco cryptographic products does not
imply third-party authority to import, export,
distribute, or use encryption. Importers, exporters,
distributors and users are responsible for compliance
with U.S. and local country laws. By using this
product you agree to comply with applicable laws and
regulations. If you are unable to comply with U.S.
and local laws, return the enclosed items immediately.
A summary of U.S. laws governing Cisco cryptographic
products may be found at:
If you require further assistance please contact us by
sending email to export@cisco.com.
******************************* Warning *******************************
Copyright (c) 1996-2012 by Cisco Systems, Inc.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Reading from flash...
Cryptochecksum (unchanged): 4e8386d1 7cfcf9f4 73cd9c26 8aa87401
Type help or '?' for a list of available commands.
ciscoasa>
Hi Bro
The “IO memory blocks requested from bigphys 32bit: 9672” clearly indicates something isn’t right either with the FLASH CARD or the software image.
Cisco has a built in file check utility to fix problems just like this. Many folks who are familiar with unix systems also know the file system check or fsck utility.
To fix this problem, from the command prompt run fsck...
FW01# fsck disk0:
If this is successful you should see the following output:
FW01# fsck of disk0: complete
Assuming the above steps don't work out for you, please do the following;
