Welcome to Cisco Firewalls Community
8820
Cisco ASA Practice Lab Material or Books
Hello All,
I'm in the process of learning how to configure Cisco ASA. I've got the ASA simulated on GNS3.
Can some tell me where I can find books or material that has actual labs included in the book.
The books I have found seem to be handbook type of material. I need something that steps through a lab.
Cheers
Carlton
Everyone's tags (6)
15 REPLIES 15
Hello Carlton,
You can always use the certifications books from Cisco, one each chapter they explain a feature and you can see a lab recreation ( configuration part) so you can implemented by yourself following the book and understanding the logic,
That is my opinion and what I have used so far.
Julio
Cisco Security Engineer
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Re: Cisco ASA Practice Lab Material or Books
Hi Julio, thanks for responding.
I have found a site with many ASA lab samples. The problem is I don't know how to test the lab... Attached is one of the labs I'm about to build. Can someone describe how I can test the lab?
Cheers
Carlton
Hello Carlton,
You can use a VMware machine as the internal host or another router, then configure the ASA as properly and just try to give to that host connectivity to a host on the outside interface of the ASA ( via ICMP,etc).
This lab is real simple to build on GNS. ( You can do it with 2 routers and one ASA, Just make the inside router able to ping the Outside router)
Julio
Julio Carvajal
Julio, thanks again for responding.
I have already built this on GNS. My problem is I don't know how to actually test it - how to determine if its working?
Hello Carlton,
You would need to be able to ping from the inside router to the external router (or SSH or telnet)
Do you follow me?
Julio Carvajal
Julio,
I don't understand
Julio,
I don't think a simple ping will fully test this lab ....
Hello Carlton,
I checked the document again to see if I got wrong but nop I am right.
The whole purpose of the lab setup you have there is to be able to configure Dynamic Nat for the internal network when they go to the outside world using a 8.3 or higher version.
A Ping will fully showed you if its working or not. Now if you want to do it with another service.. Just use a packet-tracer and the result should be allowed and of course you will need to check a the NAT stage.
Edit: I sent you a private message, please check it
Julio
Security Engineer
Julio Carvajal
Julio,
I have replied.....
Good but do you understand the purpose of the Lab now?
Julio Carvajal
Julio,
I will build the lab, however I still don't see how a simple ping will fully test this scenario...
What is the point with all the following commands on the ASA
object network OBJ_GENERIC_ALL
 subnet 0.0.0.0 0.0.0.0
nat (inside,outside) source dynamic OBJ_GENERIC_ALL interface
route outside 0.0.0.0 0.0.0.0 10.165.200.225
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:...
Julio,
I guess I still don't understand the purpose of the lab.....
Hello Carlton,
The purpose of the lab is do NAT on 8.3 version ( because as you will need to know from 8.2 to 8.3 or higher versions this changes a lot).
So as on the PDF is marked as important that is what you need to focus on ( NAT), that's it bro!!
The other stuff in that configuration is there by default.
So what you will need to do in this lab:
1-Interface configuration
2-Nat configuration
3-Routing configuration
Now to make it more interesting after you configure all that, try to ping from the inside host to the outside host
Let me know the result of the lab as soon as you have it!
Do rate all the helpful post
Julio
Julio Carvajal
I'll be sure to let you know..
Cheers mate.
Content for Community-Ad
FusionCharts will render here
