Network Security
Engage with peers and experts on network security topics such as FTD, FMC, FDM, CDO and ASA.
Cisco CyberSecurity
Labels
I am managing FTD-1120s with FMCv both running v7.2.1 software.  In my ACP I have a GEO rule to block all outbound traffic to China, Russia, and I few other "hotspots".   When I search for events that match this rule, most of the traffic is from inte...
tato386 by Level 6
  • 134 Views
  • 1 replies
  • 1 Helpful votes
Hello,With the older ASA 5505, 5510, 5520, etc. series devices, you could add an SSP module that would give you IDS/IPS functionality.  This functionality showed up in the ASDM GUI as an additional tab.The newer ASA 5506-X doesn't have a slot for a m...
Hi I hope your doing well in our network infrastructure  where we have Qualys to scan for vulnerabilities i can't find a solution for this certain vulnerability here are the details :Weak SSL/TLS Key Exchange impact an attacker with access to suffici...
I have a pair of ASAs that I try to add a backup ISP.   I would be creating sub interfaces on Gi0/0.  Once I default the Gi0/0, the Outside configuration would be gone from the configure, can I do the sub interfaces. configure Gi0/0.10 with nameif Ou...
ironman28 by Level 1
  • 250 Views
  • 14 replies
Hi guys, I have two 5506 boxes running 9.8.3 patch 29. I login first time with ASDM and perform whatever tasks.I left ASDM open and move to other windows (probably a browser); after couple minutes a pop up from ASDM login credetials shows up. Obvious...
