Welcome to Cisco Firewalls Community
188
Beginner
Cisco ASDM TLS issue
Hi I have Cisco ASA 5506 and I used to be able to connect to the asa via asdm, always working, but today I was told to hardening the asa, so I disabled the TLS 1.0/1.1 only allow TLS1.2, see below command
ssl server-version tlsv1.2
ssl client-version tlsv1.2
ssl cipher tlsv1.2 high
ssl dh-group group24
and after I done this, I just couldn't connect to ASDM anymore, I can still ssh to the asa fine, when troubleshoot the from the java console it just said HandshakeException: Received fatal alert: handshake_failure
so is there anyway I can still use asdm but not enable tls1.0/1.1? many thanks
1 REPLY 1
VIP Advisor
Re: Cisco ASDM TLS issue
Make sure that your ASDM version supports your handshake version. Also, you
need to upgrade your JRE to supported version.
Also, you may want to have Java Cryptography extension
https://www.oracle.com/technetwork/java/javase/downloads/jce8-download-2133166.html
See this post for more details
https://community.cisco.com/t5/security-analytics-and/asdm-aes-256-not-supported/td-p/2790184
**** remember to rate useful posts
