11-13-2015 01:38 PM - edited 03-11-2019 11:53 PM
FYI - when setting up the Cisco Firepower Management Center virtual appliance v 6.0.0 the default password changed from Sourcefire to Admin123.
All documentation for 5.4 says to login with username: admin password: Sourcefire
I had to call TAC because I couldn't find any documentation on the new version. TAC found that the new password is Admin123
Hope this helps.
Arturo
Solved! Go to Solution.
11-13-2015 01:56 PM
So sorry, but Feedback Forum is dedicated to other topics. See description for details.
I has moved this thread to Firewalling
11-13-2015 01:56 PM
01-04-2017 08:28 PM
i have the same issue
i cant reset or change the root password.
it not, blank, password, Sourcefire or Admin123
there is no documention
i cant do sudu or su roout to help upgrade my system. can TAC please help?
11-16-2015 09:36 AM
Thanks ciscolicensing11! Now did you get root access to the VM to kick off the network-configure script with a different password?
I am waiting for a callback from TAC on that currently. I have tried Admin123,Sourcefire, and blank none of which has worked.
Thanks!
12-01-2017 02:11 AM
