Network Security
Engage with peers and experts on network security topics such as FTD, FMC, FDM, CDO and ASA.
Cisco CyberSecurity
Labels
Hello. I install ASA 5506-X with firepower.But When i install ASDM launcher 1.9, I can't connect ASA firepower in ASDM.I delete ASDM launcher 1.9 and install ASDM launcher 1.8, I can connect ASA firepower in ASDM well.Certificate warning occurs when ...
GaeMi by Level 1
  • 929 Views
  • 2 replies
Hello I am working with a network that has currently 10 router nodes using IPSec tunneling to communicate and encrypt packets between the 10 router nodes over a wan. Using 140.0.0.0/30 (64 tunnels total) for IPSec Tunneling I have consumed almost all...
JNC3 by Level 1
  • 112 Views
  • 4 replies
    Hi. I am most of the way through implementing an ASA 5508-x, controlled by a vFMC. Both are running 6.2.2.0 of the FTD and FMC software. Since the configuration is quite complex, and I would hate to have to do it all again from scratch, I figured...
itsupport by Level 1
  • 20008 Views
  • 16 replies
Hi,Our Cisco ASA running on Firepower 2120 hardware are being targeted by botnet DDoS doing random unauthorized login attempts originating from TOR network exit points or infected webservers and devices all over the world. The syslog is flooded with:...
Resolved! WAF in FW ?
HelloI have a very important questionI worked on security projects in Cisco and Fortigatequestion : i want to know if FW cisco have WAF : yes or not ? if yes how ?and also of FW fortigate have WAF ?i wait a reply from expert securityThanks
