Welcome to Cisco Firewalls Community
882
Beginner
Comcast and Cisco ASA 5510
I have this problem and Comcast is not a help in resolving.
We just changed  over to Comcast Business and after changing the outside interface to new IP and setting static route.
I have access to internet and everythig appears to be good,
However asdm will never fully load, alway stuck at 17% or 77%, and I always see "parsing running config"
When I do a show run it will not fully load either, always stop at certain out put.
5 seconds after pulling the Comcast cable out both asdm and running config will load fine
Can any one help?
1 ACCEPTED SOLUTION
Hello Duong,
CPU at 100% there is our problem!!!
Your box is on fireeeee... Let me know when you have access to the box so we can work on this
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
12 REPLIES 12
Hello Duong,
Any logs from the ASA that you can share with us while the issue happens?
Check memory, CPU while using the COMCAST connection
Julio Carvajal
Beginner
Merry Christmas Brother!  Thanks for answering!
For some reason cpu is 100 percent and traffic bandwidth is 500kbps.
I am not on site so I cant see the log file right now.
BTW my site to site tunnel didn't work, I used your instructions:
So only do the following: Lets say new ip is 4.4.4.4
clear configure tunnel-group 2.2.2.2
tunnel-group  4.4.4.4 type ipsec-l2l
tunnel-group 4.4.4.4 ipsec-attributes
pre-shared key x.x.x.x
no crypto map outside_map 20 set peer 2.2.2.2
crypto map outside_map 20 set peer 4.4.4.4
Hello Duong,
Julio
Julio Carvajal
Beginner
I am curious why its at 100 percent, nothing is plugged in beside Comcast Box.
Will you be available to help me Wednesday?  If so what is the best time for you?
Hello Duong,
I guess, let me know on wednesday
Julio Carvajal
Beginner
I was able to see the log today.
It is filled with these exact lines.
7|Dec 25 2012|11:27:55|609001|172.16.121.11||||Built local-host outside:172.16.121.11
How to stop this?
Beginner
Hi Bro.
I found and deleted that connection.
CPU now down to 5%
Please help me with site to site, then I can rest for Christmas.
Looks like that host is eating your network...
Why is he trying to build that much connections??
While you have it down to 5 % can you access it?
Julio Carvajal
Beginner
Yes I can connect now and have full access to FW
As expected
Who is 172.16.121.11 and what is he doing ??
sh local | in host|count/limit
That command will help you finding the amount of connections per host
This might be a computer with a virus or a bad application,etc,etc but the thing is that you could not access it because the ASA was overwhelmed by that PC.
So the problem is the PC,
That solves our paradigm,
Julio Carvajal
Beginner
That IP belonged to the consultant the company hired before I was employed.
He is their firewall guy.
There was  a VPN tunnel to that IP address.
I want to learn FW to take over that position and further my career.
Good to know that
Well that is why we are here, In order to keep learning,
Julio Carvajal.S
Julio Carvajal
Content for Community-Ad
FusionCharts will render here
