Welcome to Cisco Firewalls Community
154
Beginner
Configure multiple Subnet-based VLANs on UCS-E Series Blade on ISR 4K
Hello All,
I require some guide line here. I need to configure a UCS-E Series ( UCS-E140S-M2/K9 ). There will be an ASAv VM at UCS- Series behind which I need to isolate the Inside Resources. So there will be 1 Outside and multiple Inside Subnet need to confiugred at ASAv. So I need to bring this subnets through the UCS Router to UCS-E Series Blade. Now I am in confusion with how to make the Internal Connection with Router to UCS Blade ( ESXI Host ) for multiple  subnet to configure in ESXI. I used Routers G0/0/0 and UCS1/0/0 for CIMC IP Configuration.
Then My only left port is UCS1/0/1 to make internal connection between Router and UCS. But how to do that to make an Internal Connection with Router and UCS-E while making sure I can configure multiple subnet in UCS-E Side ?
Everyone's tags (1)
3 REPLIES 3
Rising star
Re: Configure multiple Subnet-based VLANs on UCS-E Series Blade on ISR 4K
Is this your lab setup. or actually an production network requirement. would be great if you have a network diagram requirement.
please do not forget to rate.
Beginner
Attached the Logical Diagram.
VIP Advocate
Check out this link
https://kb.vmware.com/s/article/1004074
hope it helps
Please remember to rate and select a correct answer
