Creating a simple static ip
par13
I have created a simple static ip address by using this command:
interface Vlan1
nameif inside
security-level 100
ip address 10.2.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 152.18.75.132 255.255.255.240
access-list outside_access_in extended permit ip any host 152.18.75.133
static (inside,outside) 152.18.75.133 10.2.1.2 netmask 255.255.255.255
access-group outside_access_in in interface outside
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 152.18.75.129 1
But, no matter what, the I can't ping the static address or access the computer 10.2.1.2 from outside of the asa 5505. I have attempted to ping from inside of the asa 5505 or from another computer. I just does not work.
I also have created several rules that allows icmp traffic.
icmp unreachable rate-limit 1 burst-size 1
icmp permit any echo-reply inside
icmp permit 10.2.1.0 255.255.255.0 inside
icmp permit any echo-reply outside
icmp permit any outside
What am I doing wrong?
Did you enable ICMP inspection?
SInce this is a 5505 and you are using VLANs did you assigs the vlan to the switchport in the inside and outside?
