Deny IP due to Land Attack same My IP
Ivan Marinovic
I keep receiving log messages on ASA 5545X like this:
2 Apr 06 2018 07:47:57   19.19.20.4   19.19.20.4   Deny IP due to Land Attack from 19.19.20.4 to 19.19.20.4
This is for server -  IP which is 1-to-1 NAT
10.1.4.4 ->19.19.20.4
CONFIG:
object network 19.19.20.4-10.1.4.4
nat (inside,outside) static 19.19.20.4 dns
host 10.1.4.4
and same happens with this log:
This is for local host/network 10.44.0.0  -  IP which is 1-to-many NAT
2 Apr 06 2018 07:48:23   19.19.20.244   19.19.20.244   Deny IP due to Land Attack from 19.19.20.244 to 19.19.20.244
CONFIG:
object network 19.19.20.244-10.44.0.0
nat (inside,outside) dynamic 19.19.20.244
subnet 10.44.0.0 255.255.0.0
Is something with NAT config wrong?
Best regards,
Ivan
Bogdan Nita
Hi Ivan,
Land Attack simply means the packets have the same source ip and destination ip, in your case it seems to be 19.19.20.4 and 19.19.20.244.
Is it possible that 10.1.4.4 is sending packets to 19.19.20.4, or 10.44.0.0/24 to 19.19.20.244 ?
You can set up some captures to find out.
If yes configure identity nat for that specific destination.
Bogdan
Maybe create a nonat rule to packets on the same private network?
