Welcome to Cisco Firewalls Community
47
Beginner
Denying MAC and IPs on same interface
i have a C1921 router and i would like to have ACL that dines some IPs and some MACs on internal interface. Is that possible to do? I know that you can have only 1 ACL per interface and that probably you can't combine MAC and Ip addresses in one ACL so just wanted to confirm that is not possible.
Maybe some other way to do what i want?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Rising star
Hi damir2405If you want to
If you want to block a MAC address on a Cisco router please follow the next procedure:
class-map MACBLOCKED
match source-address mac xxxx.xxxx.xxxx
policy-map MACDENIED
class MACBLOCKED
drop
interface x/x
service-policy input MACDENIED
Please rate helpful post.
Hope this helps
-Randy -
1 REPLY 1
Rising star
class MACBLOCKED
drop
interface x/x
Hope this helps
-Randy -
Content for Community-Ad
FusionCharts will render here
