Dispatch Unit - High CPU
edward ventura
Hi All,
I'm trying to do some research on the Dispatch Unit process.  It seems High CPU and this process go hand in hand.  I haven't figured out an effective way of determining what underlying issue is the actual source.  Can someone point me in the right direction to try an understand what the Dispatch Unit process is doing?  I have an ASA 5550.  I have seen the cpu hover around 85% +- 5% for sustained long periods, 30 - 60 min +.  I have always been under the impression that around 80% cpu and you're probably dropping packets (that could be an out-dated belief).
Any help to understand this is much appreciated.
-E
62 Replies 62
After shutting down the second ASA last night after production hours, the first ASA process dropped to below 5% from 90%. WOW! How can I configure the failover so it will not use so many resources on our primary ASA? By the way, this is a active/active failover configuration.
Jose,
Here's the output of show traffic:
# show traffic
Outside:
        received (in 75198.690 secs):
                208421961 packets       37346123973 bytes
                2029 pkts/sec   496004 bytes/sec
        transmitted (in 75198.690 secs):
                222072538 packets       205751735542 bytes
                2039 pkts/sec   2736050 bytes/sec
      1 minute input rate 3322 pkts/sec,  553709 bytes/sec
      1 minute output rate 3548 pkts/sec,  3005054 bytes/sec
      1 minute drop rate, 54 pkts/sec
      5 minute input rate 3302 pkts/sec,  636971 bytes/sec
      5 minute output rate 3349 pkts/sec,  2696042 bytes/sec
      5 minute drop rate, 51 pkts/sec
_10.128.0.0/22:
        received (in 75198.700 secs):
                253751434 packets       156867639032 bytes
                3031 pkts/sec   2086041 bytes/sec
        transmitted (in 75198.700 secs):
                265343188 packets       168304694868 bytes
                3014 pkts/sec   2238018 bytes/sec
      1 minute input rate 3916 pkts/sec,  2196797 bytes/sec
      1 minute output rate 4152 pkts/sec,  2878909 bytes/sec
      1 minute drop rate, 24 pkts/sec
      5 minute input rate 3754 pkts/sec,  1926199 bytes/sec
      5 minute output rate 4102 pkts/sec,  2861616 bytes/sec
      5 minute drop rate, 20 pkts/sec
_10.128.8.0/22:
        received (in 75200.640 secs):
                1642689962 packets      498513402820 bytes
                21044 pkts/sec  6629054 bytes/sec
        transmitted (in 75200.640 secs):
                1572945227 packets      361262655364 bytes
                20002 pkts/sec  4803012 bytes/sec
      1 minute input rate 28113 pkts/sec,  8903301 bytes/sec
      1 minute output rate 26733 pkts/sec,  5808062 bytes/sec
      1 minute drop rate, 16 pkts/sec
      5 minute input rate 29663 pkts/sec,  9177910 bytes/sec
      5 minute output rate 28354 pkts/sec,  6555386 bytes/sec
      5 minute drop rate, 16 pkts/sec
_10.128.16.0/22:
        received (in 75200.660 secs):
                1319780654 packets      275137499721 bytes
                17036 pkts/sec  3658025 bytes/sec
        transmitted (in 75200.660 secs):
                1327965762 packets      278510087425 bytes
                17030 pkts/sec  3703045 bytes/sec
      1 minute input rate 21974 pkts/sec,  4380562 bytes/sec
      1 minute output rate 22365 pkts/sec,  5002410 bytes/sec
      1 minute drop rate, 7 pkts/sec
      5 minute input rate 23479 pkts/sec,  4984938 bytes/sec
      5 minute output rate 23855 pkts/sec,  5312337 bytes/sec
      5 minute drop rate, 7 pkts/sec
_10.128.24.0/22:
        received (in 75203.440 secs):
                11594726 packets        1408824361 bytes
                39 pkts/sec     18048 bytes/sec
        transmitted (in 75203.440 secs):
                6481479 packets 5896153923 bytes
                29 pkts/sec     78002 bytes/sec
      1 minute input rate 131 pkts/sec,  7866 bytes/sec
      1 minute output rate 76 pkts/sec,  93358 bytes/sec
      1 minute drop rate, 42 pkts/sec
      5 minute input rate 195 pkts/sec,  24999 bytes/sec
      5 minute output rate 133 pkts/sec,  94997 bytes/sec
      5 minute drop rate, 42 pkts/sec
_10.128.32.0/22:
        received (in 75203.450 secs):
                92815175 packets        26235059135 bytes
                1005 pkts/sec   348054 bytes/sec
        transmitted (in 75203.450 secs):
                89803120 packets        20612026075 bytes
                1022 pkts/sec   274026 bytes/sec
      1 minute input rate 520 pkts/sec,  162533 bytes/sec
      1 minute output rate 478 pkts/sec,  89568 bytes/sec
      1 minute drop rate, 14 pkts/sec
      5 minute input rate 663 pkts/sec,  250859 bytes/sec
      5 minute output rate 587 pkts/sec,  113413 bytes/sec
      5 minute drop rate, 14 pkts/sec
_10.128.40.0/22:
        received (in 75203.870 secs):
                80316956 packets        23201250355 bytes
                1010 pkts/sec   308054 bytes/sec
        transmitted (in 75203.870 secs):
                77343096 packets        13738098832 bytes
                1028 pkts/sec   182049 bytes/sec
      1 minute input rate 376 pkts/sec,  62748 bytes/sec
      1 minute output rate 381 pkts/sec,  61449 bytes/sec
      1 minute drop rate, 5 pkts/sec
      5 minute input rate 373 pkts/sec,  62327 bytes/sec
      5 minute output rate 383 pkts/sec,  62409 bytes/sec
      5 minute drop rate, 5 pkts/sec
_10.128.48.0/22:
        received (in 75203.880 secs):
                844561 packets  65150815 bytes
                11 pkts/sec     9 bytes/sec
        transmitted (in 75203.880 secs):
                580216 packets  213830752 bytes
                7 pkts/sec      2043 bytes/sec
      1 minute input rate 8 pkts/sec,  506 bytes/sec
      1 minute output rate 4 pkts/sec,  336 bytes/sec
      5 minute input rate 13 pkts/sec,  1254 bytes/sec
      5 minute output rate 10 pkts/sec,  5263 bytes/sec
_10.128.56.0/22:
        received (in 75204.260 secs):
                5840632 packets 806587116 bytes
                20 pkts/sec     10039 bytes/sec
        transmitted (in 75204.260 secs):
                4914756 packets 2795547551 bytes
                8 pkts/sec      37001 bytes/sec
      1 minute input rate 69 pkts/sec,  9491 bytes/sec
      1 minute output rate 48 pkts/sec,  14357 bytes/sec
      1 minute drop rate, 12 pkts/sec
      5 minute input rate 63 pkts/sec,  8624 bytes/sec
      5 minute output rate 44 pkts/sec,  12250 bytes/sec
      5 minute drop rate, 12 pkts/sec
_10.128.64.0/22:
                2185810 packets 320219661 bytes
                29 pkts/sec     4029 bytes/sec
                1823817 packets 1037118395 bytes
                24 pkts/sec     13048 bytes/sec
      1 minute input rate 41 pkts/sec,  7173 bytes/sec
      1 minute output rate 36 pkts/sec,  17012 bytes/sec
      5 minute input rate 38 pkts/sec,  7202 bytes/sec
      5 minute output rate 33 pkts/sec,  16085 bytes/sec
_10.128.72.0/22:
        received (in 75204.640 secs):
                177402493 packets       116856273193 bytes
                2016 pkts/sec   1553044 bytes/sec
        transmitted (in 75204.640 secs):
                197227038 packets       70383945234 bytes
                2051 pkts/sec   935042 bytes/sec
      1 minute input rate 2981 pkts/sec,  1889127 bytes/sec
      1 minute output rate 3282 pkts/sec,  1150724 bytes/sec
      1 minute drop rate, 1 pkts/sec
      5 minute input rate 3138 pkts/sec,  2032268 bytes/sec
      5 minute output rate 3433 pkts/sec,  1221316 bytes/sec
      5 minute drop rate, 1 pkts/sec
_10.128.128.0/22:
        received (in 75204.650 secs):
                0 packets       0 bytes
                0 pkts/sec      0 bytes/sec
        transmitted (in 75204.650 secs):
                0 packets       0 bytes
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
_10.128.136.0/22:
        received (in 75205.130 secs):
                53627165 packets        7014820460 bytes
                27 pkts/sec     93047 bytes/sec
        transmitted (in 75205.130 secs):
                72758537 packets        26011371282 bytes
                53 pkts/sec     345015 bytes/sec
      1 minute input rate 843 pkts/sec,  124047 bytes/sec
      1 minute output rate 1096 pkts/sec,  373609 bytes/sec
      5 minute input rate 860 pkts/sec,  122931 bytes/sec
      5 minute output rate 1139 pkts/sec,  389460 bytes/sec
_10.128.144.0/22:
                11151104 packets        9034746371 bytes
                34 pkts/sec     120020 bytes/sec
                10570043 packets        5107144743 bytes
                26 pkts/sec     67052 bytes/sec
      1 minute input rate 108 pkts/sec,  81740 bytes/sec
      1 minute output rate 87 pkts/sec,  25425 bytes/sec
      1 minute drop rate, 6 pkts/sec
      5 minute input rate 85 pkts/sec,  57718 bytes/sec
      5 minute output rate 71 pkts/sec,  20822 bytes/sec
      5 minute drop rate, 6 pkts/sec
_10.128.152.0/22:
        received (in 75205.740 secs):
                0 packets       0 bytes
        transmitted (in 75205.740 secs):
                0 packets       0 bytes
_10.128.160.0/22:
        received (in 75206.450 secs):
                0 packets       0 bytes
        transmitted (in 75206.450 secs):
                0 packets       0 bytes
_10.128.168.0/22:
        received (in 75206.460 secs):
                546653 packets  101448382 bytes
                7 pkts/sec      1006 bytes/sec
        transmitted (in 75206.460 secs):
                452861 packets  121512503 bytes
                6 pkts/sec      1044 bytes/sec
      1 minute input rate 8 pkts/sec,  1775 bytes/sec
      1 minute output rate 7 pkts/sec,  2220 bytes/sec
      1 minute drop rate, 2 pkts/sec
      5 minute input rate 6 pkts/sec,  1119 bytes/sec
      5 minute output rate 5 pkts/sec,  1422 bytes/sec
      5 minute drop rate, 2 pkts/sec
_10.128.176.0/22:
        received (in 75207.280 secs):
                1654399 packets 104226916 bytes
                21 pkts/sec     1043 bytes/sec
        transmitted (in 75207.280 secs):
                5 packets       140 bytes
      1 minute input rate 22 pkts/sec,  1387 bytes/sec
      1 minute drop rate, 22 pkts/sec
      5 minute input rate 21 pkts/sec,  1385 bytes/sec
      5 minute drop rate, 21 pkts/sec
_10.128.184.0-22:
        received (in 75207.290 secs):
                9451429037 packets      963167754265 bytes
                125043 pkts/sec 12806040 bytes/sec
        transmitted (in 75207.290 secs):
                9449637158 packets      964365936576 bytes
                125019 pkts/sec 12822029 bytes/sec
      1 minute input rate 142944 pkts/sec,  14968100 bytes/sec
      1 minute output rate 142929 pkts/sec,  15001761 bytes/sec
      5 minute input rate 142935 pkts/sec,  16263929 bytes/sec
      5 minute output rate 142946 pkts/sec,  16369497 bytes/sec
      5 minute drop rate, 22 pkts/sec
_10.128.254.0/24:
        received (in 75208.310 secs):
                5 packets       210 bytes
        transmitted (in 75208.310 secs):
                5 packets       140 bytes
_10.128.4.0/24:
                301765 packets  20868161 bytes
                4 pkts/sec      49 bytes/sec
                184444 packets  61681415 bytes
                2 pkts/sec      20 bytes/sec
      1 minute input rate 3 pkts/sec,  185 bytes/sec
      1 minute output rate 1 pkts/sec,  101 bytes/sec
      5 minute input rate 5 pkts/sec,  523 bytes/sec
      5 minute output rate 4 pkts/sec,  2280 bytes/sec
_10.128.12.0/24:
        received (in 75210.220 secs):
                22745947 packets        3639962309 bytes
                16 pkts/sec     48054 bytes/sec
        transmitted (in 75210.220 secs):
                22903577 packets        5248957258 bytes
                18 pkts/sec     69048 bytes/sec
      1 minute input rate 15 pkts/sec,  1053 bytes/sec
      1 minute output rate 8 pkts/sec,  604 bytes/sec
      5 minute input rate 17 pkts/sec,  1344 bytes/sec
      5 minute output rate 11 pkts/sec,  2017 bytes/sec
_10.128.20.0/24:
        received (in 75210.240 secs):
                114444 packets  8931404 bytes
                1 pkts/sec      4 bytes/sec
        transmitted (in 75210.240 secs):
                39356 packets   21604411 bytes
                0 pkts/sec      1 bytes/sec
      1 minute input rate 1 pkts/sec,  75 bytes/sec
      1 minute output rate 0 pkts/sec,  26 bytes/sec
      5 minute input rate 1 pkts/sec,  76 bytes/sec
      5 minute output rate 0 pkts/sec,  27 bytes/sec
management:
        received (in 75211.170 secs):
                0 packets       0 bytes
        transmitted (in 75211.170 secs):
                0 packets       0 bytes
Failover:
                122235 packets  9462594 bytes
                1 pkts/sec      11 bytes/sec
                104695462 packets       122719152012 bytes
                1049 pkts/sec   1631033 bytes/sec
      1 minute input rate 1 pkts/sec,  132 bytes/sec
      1 minute output rate 1878 pkts/sec,  2209723 bytes/sec
      5 minute input rate 1 pkts/sec,  125 bytes/sec
      5 minute output rate 1864 pkts/sec,  2191041 bytes/sec
Aggregated Traffic on Physical Interface
GigabitEthernet0/0:
        received (in 75213.390 secs):
                208545871 packets       41317080799 bytes
                2030 pkts/sec   549045 bytes/sec
        transmitted (in 75213.390 secs):
                222124681 packets       209881403010 bytes
                2039 pkts/sec   2790022 bytes/sec
      1 minute input rate 3323 pkts/sec,  617355 bytes/sec
      1 minute output rate 3548 pkts/sec,  3070853 bytes/sec
      5 minute input rate 3303 pkts/sec,  700108 bytes/sec
      5 minute output rate 3349 pkts/sec,  2758109 bytes/sec
GigabitEthernet0/1:
        received (in 75215.180 secs):
                13130672114 packets     2374554306559 bytes
                174003 pkts/sec 31570033 bytes/sec
        transmitted (in 75215.180 secs):
                13102757674 packets     2214951524662 bytes
                174032 pkts/sec 29448026 bytes/sec
      1 minute input rate 202068 pkts/sec,  37244150 bytes/sec
      1 minute output rate 201678 pkts/sec,  34955424 bytes/sec
      5 minute input rate 205320 pkts/sec,  39446332 bytes/sec
      5 minute output rate 205116 pkts/sec,  37554821 bytes/sec
GigabitEthernet0/2:
        received (in 75215.190 secs):
                0 packets       0 bytes
        transmitted (in 75215.190 secs):
                0 packets       0 bytes
GigabitEthernet0/3:
        received (in 75216.150 secs):
                122244 packets  11700024 bytes
                1 pkts/sec      41 bytes/sec
        transmitted (in 75216.150 secs):
                104705012 packets       124615107776 bytes
                1049 pkts/sec   1656017 bytes/sec
      1 minute input rate 1 pkts/sec,  169 bytes/sec
      1 minute output rate 1878 pkts/sec,  2243149 bytes/sec
      5 minute input rate 1 pkts/sec,  154 bytes/sec
      5 minute output rate 1864 pkts/sec,  2224601 bytes/sec
Internal-Data0/0:
        received (in 75216.160 secs):
                0 packets       0 bytes
        transmitted (in 75216.160 secs):
                0 packets       0 bytes
Management0/0:
        received (in 75216.970 secs):
                0 packets       0 bytes
        transmitted (in 75216.970 secs):
                0 packets       0 bytes
GigabitEthernet1/0:
                0 packets       0 bytes
                0 packets       0 bytes
GigabitEthernet1/1:
        received (in 75217.600 secs):
                0 packets       0 bytes
        transmitted (in 75217.600 secs):
                0 packets       0 bytes
GigabitEthernet1/2:
                0 packets       0 bytes
                0 packets       0 bytes
GigabitEthernet1/3:
        received (in 75218.330 secs):
                0 packets       0 bytes
        transmitted (in 75218.330 secs):
                0 packets       0 bytes
Internal-Data1/0:
        received (in 75218.830 secs):
                0 packets       0 bytes
        transmitted (in 75218.830 secs):
                0 packets       0 bytes
Per Slot Throughput Profile (1 minute)
  Packets-per-second profile:
    Slot 0:     412496 100%|**************************************************
    Slot 1:          0   0%|
  Bytes-per-second profile:
    Slot 0:   78131100 100%|**************************************************
    Slot 1:          0   0%|
Hello Edward,
Its Julio no Jose.
It is not oversubscribed, can you prodide the following:
show interface | i errors
show conn count
show resource usage
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio,
Sorry about that.  Not sure why I wrote Jose.
# show interface | i errors
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        271529 input errors, 0 CRC, 0 frame, 271529 overrun, 0 ignored, 0 abort
        0 output errors, 0 collisions, 2 interface resets
        0 output errors, 0 collisions, 1 interface resets
# show conn count
115639 in use, 139617 most used
# show resource usage
Resource               Current        Peak      Limit        Denied Context
SSH                          1           5          5             0 System
Syslogs [rate]           11891      101524        N/A             0 System
Conns                   114891      139617     650000             0 System
Xlates                     534        2033        N/A             0 System
Hosts                    12642       15480        N/A             0 System
Conns [rate]              1477       12858        N/A             0 System
Inspects [rate]             76         753        N/A             0 System
# show cpu
CPU utilization for 5 seconds = 62%; 1 minute: 63%; 5 minutes: 67%
First time I've used show resource usage.  I like.
-E
Glad you like the command, As we can see there are a lot of connections, next thing would be to check if there is a host consuming a lot of connections (zombie or a PC with a virus)
I am quite sure you are going to like this command:
sh local | in host|count/limit
This will tell us the amount of connections per host, if you see one with a high number of connectios go inmediatly to that PC turn it off and check the CPU on the ASA,
Do rate all the helpful posts!
Julio
Julio Carvajal
Julio,
I'm trying to understand what is considered too many connections and how those connections impact the ASA.  I'm assuming to a degree resources are consumed to maintain a state table of all the connections but wouldn't think that would reflect in CPU usage.
Also, the 'sh local | i host|count/limit' is awesome! Is there by any chance a way to sort by highest count.  I have over a thousand to sort through.  I was hoping I could do it via cli but if not I can get creative with notepad++.
Thanks again for your help!
-Eddie
Julio,
Would you consider this suspicious?
local host: ,
    TCP flow count/limit = 47/unlimited
    TCP embryonic count to host = 0
    TCP intercept watermark = unlimited
    UDP flow count/limit = 18121/unlimited
Yeap, look at the amount of UDP sessions!!! 18121 that is way tooooooooooo much!
regards,
Julio
Julio Carvajal
Julio,
The only issue is that the cpu usage and high connections don't match up.  The cpu was at 46%.  My cpu just spiked to 91%.
same host
local host: ,
    TCP flow count/limit = 53/unlimited
    UDP flow count/limit = 7670/unlimited
0x081d8531   0x1bdc1528    89.7%    88.9%    84.5%   Dispatch Unit
This is troubling
Can you remove that host from your network then do a
clear conn address ,
And then check the cpu
Julio Carvajal
jyothydas
Can you also tell the total memory of your asa?
Free memory:        3358598679 bytes (78%)
Used memory:         936368616 bytes (22%)
Total memory:       4294967295 bytes (100%)
Hello Edward,
Thank you very much for the post.
I also had a same experience in ASA 5520, it shows a cpu utilization of 95% where 90% is due to dispatch unit.
After checking with ASA and Edge router(cache-flow) we found that it's due to mass traffic generated from a host inside our network.
As soon as we moved the host from our network, suddenly everything starts working fine .
Randeep.A.R
Correct, That is what it seems to be happening here as well:
local host: ,
Julio Carvajal
Would you be able to provide the show conn of the ASA? Based on the first service policy that you guys put (the inspection should have not been removed) ICMP has a huge amount of packets. I need to take a look at some details on that specific output and then I will ask you to take some packet captures.
Let me know.
Mike
Mike
