DMZ Design
NotOfEarth
I have a DMZ that has a Cisco Nexus switch with VRFs as well as a physical firewall.  Is it common in a DMZ environment to put the gateways for the DMZ systems on a Nexus VRF? Or should they be on the physical firewall?  If they are on the VRF, then it would be much easier for a misconfiguration to allow traffic between two subnets where traffic shouldn't flow.  If they are on the physical firewall, then there is a greater performance hit to the firewall to process more traffic, but greater visibility and centralized enforcement traffic flow policies between subnets.
Your experiences and recommendations welcome...
Philip D'Ath
The routing needs to be symmetric.  It is is just a single subnet I would take the Nexus switch out of that network (at a layer 3 level) and just run everything through the firewall.
