Drop-reason: (acl-drop) Flow is denied by configured rule
CY Ko
Actually, I want to allow FTP from outside to inside, but the packet tracer display "Drop-reason: (acl-drop) Flow is denied by configured rule".   I must be wrong something.  I have attached my config.  Any assistance would be greatly appreciated.
9 Replies 9
try this
object network ANY
 subnet 0.0.0.0 0.0.0.0
nat (outside,inside) source dynamic ANY   interface destination static FTP_Inside FTP_Inside service FTP FTP
"Where ANY is outside world could be any public ip address and interface mean your ASA outside interface"
also
remove this
no same-security-traffic permit inter-interface
no same-security-traffic permit intra-interface
make sure you do this in change window.
Regards.
please do not forget to rate.
I had a look on your config here are my thoughts
ASA Version 9.1(2)
interface GigabitEthernet0/0
 nameif outside
 security-level 0
 ip address dhcp
interface GigabitEthernet0/1
 nameif inside
 security-level 100
 ip address 192.168.1.254 255.255.255.0
ftp mode passive
//////////////////////NO NEED TO THESE COMMAND////////
object network INSIDE_SUBNET
 subnet 192.168.1.0 255.255.255.0
 nat (inside,outside) source dynamic any interface
object service FTP
 service tcp destination eq ftp
object network FTP_Inside (TRY THIS- DO packet tracer input outside tcp 8.8.8.8 12345 192.168.1.24 ftp detail)
 host 192.168.1.24
  nat (inside,outside) static interface service tcp ftp ftp /////THIS RULE WILL CONNTED THE OUTSIDE CLIENT to ASA OUTSIDE INTERFACE IP, THAN ASA WILL MAPPED THE OUTSIDE IP TO FTP_Inside//////
object network FTP_Outside
 host x.x.x.x   (Public IP??)
object service Passive_FTP
 service tcp destination range 30000 35000
object service passive_FTP
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
access-list Outside_access_in extended permit tcp any host 192.168.1.24
no access-list Outside_access_in extended permit tcp object FTP_Outside object FTP_Inside eq ftp
no access-list Outside_access_in extended permit tcp object FTP_Outside object FTP_Inside eq ftp-data
no access-list Outside_access_in extended permit tcp any object FTP_Outside eq ftp
/////You dont need this as traffic from inside to outside (higher to lower) does not need access-rule////
no access-list inside_access_in extended permit ip any any
access-list global_access extended permit tcp any any
//////////////////////////////////DONT NEED THIS//////////////////////
nat (outside,outside) source dynamic any interface destination static FTP_Inside FTP_Inside service FTP FTP
access-group Outside_access_in in interface outside
/////////////////////////////////NO NEED THIS////////////////////
access-group inside_access_in in interface inside
access-group global_access global
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
Dear sherazrose,
1. object network FTP_Inside (TRY THIS- DO packet tracer input outside tcp 8.8.8.8 12345 192.168.1.24 ftp detail)
host 192.168.1.24
Ans: It still the same problem.
2. host x.x.x.x (Public IP??)
Ans:Yes
What should I next step? Thanks.
mkazam001
Level 3
Level 3
you need these cmds to allow the asa to keep the connections in the state table:
policy-map global_policy
class inspection_default
inspect ftp
ensure you have both of these in the object group:
object-group service obj-ftp tcp
port-object eq ftp
port-object eq ftp-data
access-list outside-in extended permit tcp any host ftp-svr-ip object-group obj-ftp       - enter actual svr ip
try packet-tracer input outside tcp source-ip 12345 ftp-svr-ip 21 det - to get info on where the problem may lie     - enter actual ftp server ip
regards, mk
please rate if helpful or solved :)
hi mkazam001 i thought the nat problem issue as if you see the nat statement its wrong?
i didn't mention that as you already had - nat (outside,outside) is incorrect
regards, mk
Dear mkazam001,
After that, it still the same problem. Do you have any idea what's problem is it?
yes fix you nat statement.
venkat_n7
looks like, it should be nat issue. and also use "object-group's" instead of "object network's" to be more clear with config.
creat an object grroup for ftp ports and add them in it and then use in acl to allow.
Please rate comments and support
with regards,
Venkat
