04-26-2015 07:23 AM - edited 03-11-2019 10:50 PM
Hi all,
I am having an issue that I cannot seem to figure out. Yesterday I had to replace a battery in one of my UPS units so I had to shut a bunch of stuff down. Before I did that I went into each unit and did a wr mem and a copy running to startup to make sure that I had the configs I thought I was running. Before this, I had had no packet loss and the connection was fine. After doing the battery switch, I plugged everything back in and turned them on and was back up and running, except I kept getting dropped from places and web page was slow loading and that is when I noticed the packet loss.
It is very regular and very annoying. I think that at some point I was in testing stuff and messing with the config and made a change but never wrote it and then forgot.
I was hoping you all could look over the configs for the ASA and the 2811 to see if anything looks off. Also, and I don't know if this is relevant, but I can no longer get replies back from traceroutes. I recall I used to have no issue with this, but now, everything is blocked in between the ASA and the destination even though I have it set to inspect ICMP packets.
I do not get packet loss on the inside interface or anywhere within the inside.
I know just enough to be dangerous!
Here is the ASA config:
ASA5510# sh run
: Saved
ASA Version 9.1(4)
hostname ASA5510
domain-name m.int
enable password encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd encrypted
names
dns-guard
interface Ethernet0/0
description LAN Interface
nameif Inside
security-level 100
ip address 10.10.1.1 255.255.255.252
interface Ethernet0/1
description WAN Interface
nameif Outside
security-level 0
ip address 68.233.x.x 255.255.255.128
interface Ethernet0/2
description DMZ
nameif DMZ
security-level 100
ip address 10.10.0.1 255.255.255.252
interface Ethernet0/3
description VOIP
nameif VOIP
security-level 100
ip address 10.10.2.1 255.255.255.252
interface Management0/0
management-only
shutdown
nameif management
security-level 0
no ip address
boot system disk0:/asa914-k8.bin
ftp mode passive
dns domain-lookup Inside
dns domain-lookup Outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
name-server 68.233.xx.x
domain-name m.int
same-security-traffic permit inter-interface
object network ROUTER-2811
host 10.10.1.2
object network ROUTER-2821
host 10.10.0.2
object network WEBCAM-01
host 192.168.1.5
object network DNS-SERVER
host 192.168.1.2
object network ROUTER-3745
host 10.10.2.2
object network RDP-DC1
host 192.168.1.2
object network BLUE
host 192.168.1.6
description Blue Iris Server
object network M_LAP_LEA
host 192.168.1.20
description Laptop from LEA
object-group network PAT-SOURCE
network-object 10.10.1.0 255.255.255.252
network-object 10.10.0.0 255.255.255.252
network-object 10.10.2.0 255.255.255.252
network-object 192.168.0.0 255.255.255.0
network-object 172.16.10.0 255.255.255.0
network-object 172.16.20.0 255.255.255.0
network-object 128.162.1.0 255.255.255.0
network-object 128.162.10.0 255.255.255.0
network-object 128.162.20.0 255.255.255.0
network-object 192.168.1.0 255.255.255.0
network-object 192.168.10.0 255.255.255.0
network-object 192.168.20.0 255.255.255.0
network-object 172.16.1.0 255.255.255.0
network-object 162.128.1.0 255.255.255.0
network-object 162.128.10.0 255.255.255.0
network-object 162.128.20.0 255.255.255.0
network-object 142.16.1.0 255.255.255.0
network-object 142.16.10.0 255.255.255.0
network-object 142.16.20.0 255.255.255.0
object-group network DM_INLINE_NETWORK_2
network-object host 98.22.xxx
object-group network Outside_access_in
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object gre
access-list USERS standard permit 10.10.1.0 255.255.255.0
access-list Outside_access_in extended permit tcp host 98.22.xxx object ROUTER-2811 eq ssh
access-list Outside_access_in extended permit tcp host 98.22.xxx object ROUTER-2821 eq ssh
access-list Outside_access_in extended permit tcp host 98.22.xxx interface Outside eq https
access-list Outside_access_in extended permit tcp host 98.22.xxx object WEBCAM-01 eq www inactive
access-list Outside_access_in extended permit tcp host 98.22.xxx object RDP-DC1 eq xxxx
access-list Outside_access_in extended permit tcp host 98.22.xxx object BLUE eq xxxx
access-list Outside_access_in extended permit tcp host 98.22.xxx object ROUTER-3745 eq ssh
access-list Outside_access_in extended permit tcp any object BLUE eq xxxx
access-list dmz-access-vlan1 extended permit ip 128.162.1.0 255.255.255.0 any
access-list dmz-access remark Permit all traffic to DC1
access-list dmz-access extended permit ip 128.162.1.0 255.255.255.0 host 192.168.1.2
access-list dmz-access remark Permit only DNS traffic to DNS server
access-list dmz-access extended permit udp 128.162.1.0 255.255.255.0 host 192.168.1.2 eq domain
access-list dmz-access remark Permit ICMP to all devices in DC
access-list dmz-access extended permit icmp 128.162.1.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu Inside 1500
mtu Outside 1500
mtu DMZ 1500
mtu VOIP 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any Outside
asdm image disk0:/asdm-715.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (Inside,Outside) static interface service tcp ssh x
nat (DMZ,Outside) static interface service tcp ssh x
nat (Inside,Outside) static interface service tcp www x
nat (VOIP,Outside) static interface service tcp ssh x
nat (Inside,Outside) static interface service tcp xxxx xxxx
object network BLUE
nat (any,Outside) after-auto source dynamic any interface
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 68.233.151.1 1
route DMZ 128.162.1.0 255.255.255.0 10.10.0.2 1
route DMZ 128.162.10.0 255.255.255.0 10.10.0.2 1
route DMZ 128.162.20.0 255.255.255.0 10.10.0.2 1
route VOIP 142.16.1.0 255.255.255.0 10.10.2.2 1
route VOIP 142.16.10.0 255.255.255.0 10.10.2.2 1
route VOIP 142.16.20.0 255.255.255.0 10.10.2.2 1
route Inside 172.16.10.0 255.255.255.0 10.10.1.2 1
route Inside 172.16.20.0 255.255.255.0 10.10.1.2 1
route Inside 192.168.1.0 255.255.255.0 10.10.1.2 1
route Inside 192.168.10.0 255.255.255.0 10.10.1.2 1
route Inside 192.168.20.0 255.255.255.0 10.10.1.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server PNL-RADIUS protocol radius
aaa-server PNL-RADIUS (Inside) host 192.168.1.2
key *****
radius-common-pw *****
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 Inside
http 98.22.xxx 255.255.255.255 Outside
snmp-server host Inside 192.168.1.2 community ***** version 2c udp-port 161
snmp-server location x
snmp-server contact x
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 Inside
ssh 98.22.xxx 255.255.255.255 Outside
ssh timeout 60
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 24.56.178.140 source Outside prefer
username xxxx password x encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
inspect pptp
class class-default
user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
password encryption aes
hpm topN enable
Cryptochecksum:949189d67866f6c09450769d41649992
: end
Here is the 2811:
C2811#sh run
Building configuration...
Current configuration : 3925 bytes
version 15.1
service password-encryption
hostname C2811
boot-start-marker
boot system flash
boot-end-marker
enable secret 4 x
aaa new-model
aaa session-id common
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip domain name m.int
ip name-server 192.168.1.2
ip name-server 8.8.8.8
ip name-server 68.233.xxx.x
no vlan accounting input
crypto pki trustpoint TP-self-signed-1290569776
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1290569776
revocation-check none
rsakeypair TP-self-signed-1290569776
crypto pki certificate chain TP-self-signed-1290569776
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31323930 35363937 3736301E 170D3134 30313035 30363130
33395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32393035
36393737 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B18F F63C5121 00785DE0 854601BA EE77DAA3 21286D8C 6E700C37 237CC1BE
611023AF FBE04BBE 7B4B3233 E4E129DD A74604E5 62AA39BF 77F98D5D D63944E9
2345AE37 D93C5753 E425E85A EB22C2C9 CFC5D1A0 F800449B 0419A5C8 A0A101EC
02928172 7B30A609 71ADA3D4 68F4F484 AF2B3249 0E225DB2 C72C136A E670D761
DDE30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1461F6DE 8EF50F7B 0E46359F 421EA106 9375F65F 30301D06
03551D0E 04160414 61F6DE8E F50F7B0E 46359F42 1EA10693 75F65F30 300D0609
2A864886 F70D0101 05050003 81810049 BA55F695 8525265F ED2D77EE 8706BF10
63A7E644 202F6663 9EA5551F 47F7FC50 D4021EDD E3DC5A80 39FD161A C337D20D
71B98875 0F1FE887 649E81D3 F93F7A1B A1E18B99 A77B1A59 84DB4711 867913FD
044084FB 651ECA6E C6EDF35C E43A2946 8C01781E 26DB9484 C8740A82 4A7CA266
A0655526 CBCB4982 F30D68E9 D70753
quit
license udi pid CISCO2811 sn FTX1041A07T
username x secret 5 x
username xxxx privilege 15 secret 4 x
redundancy
ip ssh time-out 60
ip ssh authentication-retries 5
ip ssh version 2
interface FastEthernet0/0
description CONNECTION TO INSIDE INT. OF ASA
ip address 10.10.1.2 255.255.255.252
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
description VLAN 10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip helper-address 192.168.1.2
interface FastEthernet0/1.2
description VLAN 20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/1.3
description Trunk Interface VLAN 1
encapsulation dot1Q 1 native
interface Dialer0
no ip address
ip default-gateway 10.10.1.1
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 10.10.1.1
ip ospf name-lookup
access-list 1 permit any
dialer-list 1 protocol ip permit
snmp-server community Maladomini-RW RW
tftp-server system:running-config 1
control-plane
line con 0
exec-timeout 0 0
password 7 x
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 0527031B2C49470758
transport input ssh
scheduler allocate 20000 1000
end
04-27-2015 04:24 AM
As per your description of the issue. This all started after the ASA device reloaded.
I don't see any misconfiguration on the ASA device. What traffic are you testing with. You have not observed any traffic issues on the inside interface correct ?
Is the traffic being dropped when going through the ASA device ? If yes , have you applied some captures on the ASA device interface and see if you see the traffic traversing through the ASA device.
I think this would be the best approach.
Use a specific Source and type of test traffic. Capture it on the ASA device and see if you get any missing packets.
Other than that check the ASA device counters:-
show asp drop
show service-policy
show interface
Thanks and Regards,
Vibhor Amrodia
