09-16-2011 07:07 AM - edited 03-11-2019 02:25 PM
Can anyone confirm what the difference between the device "up time" and the "failover cluster" uptime is as per the "show ver" output below? i've just installed a new cluster using 2 new ASA and received the below outputs.
asa-firewall> sh ver
Cisco Adaptive Security Appliance Software Version 8.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
asa-firewall up 2 days 22 hours
failover cluster up 1 year 79 days
Hardware: ASA5550, 4096 MB RAM, CPU Pentium 4 3000 MHz
Solved! Go to Solution.
09-16-2011 08:23 AM
Hi Tony,
ASA-Firewall up time is, that particular firewall is up since 2 days from the last reboot.
failover cluster up is that the failover has been working fine on yuor setup for the last 1 year and havent ever been disable.
Let me know if you have any questions,
Varun
09-16-2011 08:48 AM
Tony
I agree with the explanation of Varun. When you configure a failover cluster it starts measuring the uptime of the cluster. If the active ASA goes down then the standby ASA becomes active and the cluster continues to be up. When the first ASA reboots its system uptime starts over again but the cluster up time has continued without interruption.
But I am puzzled by something in your post. You say: "i've just installed a new cluster using 2 new ASA". But if it is really a new cluster and new ASAs then I do not see how the cluster uptime could be a year 79 days. Were they really new ASAs?
Rick
09-16-2011 11:29 AM
Tony,
I take it that you replaced one unit at a time on the failover cluster without suffering downtime. So, what you see it to be expected. Your failover cluster has been up for more than a year but, individual firewall up time is shorter as they got replaced/rebooted.
-KS
09-19-2011 06:10 PM
Exactly. Would appreciate if you could mark this thread answered.
KS
09-16-2011 08:23 AM
Hi Tony,
Varun
09-16-2011 08:48 AM
Tony
Rick
09-16-2011 09:17 AM
Rick,
I had a pair of ASAs in a cluster which both failed at the same time. So I RMA'ed them and received 2 replacements from Cisco.
After setting up the new cluster using the replacement units I issued a "show ver" and receveid the above output.
Does this suggests that these firewalls were previously turned on and configured as part of another cluster?
09-16-2011 11:29 AM
Tony,
-KS
09-19-2011 09:14 AM
Thanks guys - this makes sense now. Even though I had to replace both units - I made sure the cluster remained active throughout hence the difference in up-times.
09-19-2011 09:27 AM
Glad we could help you out with it
-Varun
09-19-2011 06:10 PM
KS
