Failover Not Sync in Active/Stanby Mode
salman-ahmad
I have found this error when i try to make Failover in Active/Standby position.
KHI-DR-ASA-BB-01# sh failover state
State          Last Failure Reason      Date/Time
This host  -    Primary
                          Active          None
Other host -  Secondary
                           Failed         Ifc Failure              16:04:50 PK Oct 15 2012
                                                inside: Failed
====Configuration State===
                Sync Done
                Sync Done - STANDBY
====Communication State===
                Mac set
What is the cause of this error and what are the steps to troublshoot to resolve my problem.
Salman Ahmed
Hello Salman,
It looks like a communication issue between ASA's over failover link.. Are you able to ping
55.0.0.2 from ASA-1 ?  and how is the failover link connected direct or via  switch ?
regards
Harish
You removed a relevant part of the config. Without knowing if you configured the interfaces right, it is hard to help you. Do you have standby-addresses on all data-interfaces?
One problem in your setup is that it is not recommended to use the management-ports as the Failover-link on the 5580. But that is probably not related to your actual problem.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
