01-14-2019 07:54 AM - edited 03-12-2019 04:19 AM
I've just tried to run up an instance of FTDv in a lab environment for testing prior to using on a customer site, the setup script allows me to manually configure a management address as usual, but this doesn't seem to be being applied correctly.
If I use "show network", I see the correctly configured IPv4 address on the inside (g0/1) interface (192.168.179.254 in my lab), but if I use "show IP" I see 192.168.45.1 on the same interface. Attempts to ping the gateway result in "no route to host", unless I drop into a shell, when the gateway becomes reachable.
I've tried setting the address with "configure network ipv4 manual" which makes no difference; nor does reloading or re-installing.
Wondering if anyone else has seen this behavior, & if so how it was resolved.
Command output below:
> show ip
System IP Addresses:
Interface Name IP address Subnet mask Method
GigabitEthernet0/0 outside unassigned unassigned DHCP
GigabitEthernet0/1 inside 192.168.45.1 255.255.255.0 CONFIG
Current IP Addresses:
> show network
===============[ System Information ]===============
Hostname : firepower
DNS Servers : 208.67.222.222
208.67.220.220
Management port : 8305
IPv4 Default route
Gateway : 192.168.179.1
======================[ br1 ]=======================
State : Enabled
Channels : Management & Events
Mode : Non-Autonegotiation
MDI/MDIX : Auto/MDIX
MTU : 1500
MAC Address : 0C:A2:4E:81:36:01
----------------------[ IPv4 ]----------------------
Configuration : Manual
Address : 192.168.179.254
Netmask : 255.255.255.0
Broadcast : 192.168.179.255
----------------------[ IPv6 ]----------------------
Configuration : Disabled
===============[ Proxy Information ]================
State : Disabled
Authentication : Disabled
01-14-2019 09:34 AM
01-14-2019 02:13 PM
If you are referring to FMC MGMT interface, all you need is to configure one IP address for MGMT, which will be use to register FTD to FMC, I would make sure FMC MGMT interface and FTD MGMT interface are in a same network.
01-15-2019 02:30 AM
01-22-2019 11:14 PM
Issue: During Image Install step of Software Image Upgrade Process, the FMC issues reboot to vFTD... and vFTD thereby becomes inaccessible due to br1 mac address changing to it's original value:
The vFTD is created in vSphere
1. After VM is created with vSphere Client for vFTD, it shows different mac addresses for br1 & NA-1 interfaces.
2. Only when br1 mac address is changed (from Console of VM/vFTD) to Network Adapter-1 mac address of the vFTD(shown in Virtual Machine Properties box) , vFTD gets accessed from FMC.
3. Upon reboot of the vFTD, the br1 gets back to it's original mac address instead of retaining the value of changed mac address(Network Adapter-1).
4. It then becomes necessary to change the br1 mac address to Network Adapter-1 mac address of the vFTD, manually through Console, to make it accessible from FMC.
How can this problem be corrected !
01-22-2019 11:59 PM
Also, you "ping system <IP>" vs. "ping <IP>" when initiating traffic from the FTD mgmt interface. Otherwise it will try to use the data interface (which one is according to the appliance's routing table).
