08-25-2019 09:40 PM
Hello ,
We seen the both FPR2110 becomes active-active suddenly.it was working fine in active-standby fail-over. we have used direct ethrenet cable for cross/sync link between to firewall. FPR2110 IS MANAGED BY fmc.
Also seen the CPU utilization primary firewall is 100%
Attached the logs.
Please help me for further troubleshooting.
08-25-2019 11:05 PM
Since the failover reason is "hello not heard from mate" and it's a direct physical connection, I would try replacing the Ethernet cable first.
The failover code is pretty stable as it is based on the code from the ASA where it has been a feature for many years. A software bug is unlikely. What version are you running?
If replacing the cable doesn't fix it then I would open a TAC case. There could be a hardware problem with one of the units.
08-26-2019 12:35 AM
Dear Marvin,
Version is 6.2.3.4 . I have replaced cable but getting same thing. The only primary device having problem as on FMC i seeing error for this. This is happening when primary device having very high cpu utilization( 100%).
Please suggest.
08-26-2019 09:25 PM
Issue still not resolved. do you have any idea on this...
08-27-2019 07:08 PM
"...open a TAC case. There could be a hardware problem with one of the units."
