05-17-2019 02:30 PM - edited 02-21-2020 09:08 AM
Say I have a object host IP, and I want to see under which object group it belongs to.
if I do show run | in IP (I only see the lines where the IP exist) not its main section and subsections.
What grep command will help me get its complete section in Cisco ASA?
05-17-2019 03:11 PM
I moved your post to Firewalls, as it's specific to ASA.
I usually use "show run object group". Also see Finding what object groups an ip addres... - Cisco Community
05-18-2019 01:45 AM
05-21-2019 02:55 PM - edited 05-21-2019 03:07 PM
so it partially helps, appreciate that. But it still show lines with text containing word object-group not relevant to my search. all I need is when I search the IP it lists down the IP and which group it is sitting under.
05-21-2019 03:12 PM
I also found this command for more refined result from other post.
#show running-config object network in-line | i x.x.x.x
