Welcome to Cisco Firewalls Community
276
Beginner
GROUP POLICY FOR DEFAULT TUNNEL-GROUP
If I am not wrong the group policies are mapped to the connection profiles (tunnel-groups) and they applied to the users based on the group they choose in the cisco any client software.
So what happens to the group policies which are not part of any tunnel-groups?.
Why such a weird question because i found some group policies not being called in any tunnel-groups.
Does that mean these group policies are not being used at all?. or Are they mapped to their respective "DEFAULT" tunnel-group type.
Everyone's tags (1)
4 REPLIES 4
Hall of Fame Guru
Re: GROUP POLICY FOR DEFAULT TUNNEL-GROUP
They could be left over from a previous configuration where they had an associated tunnel-group.
If no current tunnel-group specifies them they are likely extraneous and can be removed. (You cannot remove the default group policy, even if it's not currently used.)
VIP Advisor RJI VIP Advisor
VIP Advisor
If you don't specifically define a group policy in a tunnel-group, you would be using the default group policy "DfltGrpPolicy". You would need to use the command "show run ALL tunnel-group", which would reveal the actual group policy in use by the tunnel-group. The command "show run tunnel-group" would not reveal this.
Group Policies do not explicitly need to be referenced in the tunnel-group/connection profile, if using a RADIUS server for authorisation the Group Policy could be dynamically applied to a users session. So those group policies may in fact be in use.
Beginner
Can tell me if there's any links to this type of configuration or how to check if the group policies are mapped to users ?.
Beginner
Hi Alfred,
Group-policy that are not attached to any tunnel-group will not be in use (you can delete them).
users who does not match any tunnel-group will be assigned the Defaultwebvpngroup which is maped to the dfltgrouppolicy.
you can check each user to what tunnel-group and group-policy he is assigned by issuing this cmd from cli:
W01/pri/act# sh vpn-sessiondb anyconnect
Session Type: AnyConnect
Username : ar010 Index : 13412
Assigned IP : 10.0.15.142 Public IP : x.x.x.x
Protocol : AnyConnect-Parent SSL-Tunnel DTLS-Tunnel
License : AnyConnect Premium
Encryption : AnyConnect-Parent: (1)none SSL-Tunnel: (1)AES-GCM-256 DTLS-Tunnel: (1)AES256
Hashing : AnyConnect-Parent: (1)none SSL-Tunnel: (1)SHA384 DTLS-Tunnel: (1)SHA1
Bytes Tx : 893560189 Bytes Rx : 272695893
Group Policy : GP-SSL-All Tunnel Group : TG-SSL-Internal
Please rate if answer is helpful.
