Welcome to Firewalls
1269
Beginner
HA Configuration on Cisco FTD 2110 using Ether Channel
I am looking for assistance to configure my pair of FTDs devices ( 2100 ) in HA using Ether Channel.
I have already added my both FTDs in FMC, I have configured Ether Channels on both FTDs via Device Managament but when i try to add/configure HA for both FTDs then i am unable to see/select Etherchannel from the interface option.
attached are images for the same.
Re: HA Configuration on Cisco FTD 2110 using Ether Channel
Hello, I am experiencing this problem too. In addition, I am getting an alert message saying "Interface Portchannel is not receiving any packets". Did you find the solution?
Nim
Beginner
Yes.
Please create the port-channel without any logical name or zone, add the physical interfaces that you want to bundle in it and after that you would be able to use port-channel in the HA.
Thank you.
Hall of Fame Master
When you created your Etherchannel did you assign physical interfaces to it?
Enthusiast
I was trying this in my lab yesterday and I had some problems too.
Not sure, but looks like I had to use "channel-group 1 mode active" on the catalyst switch, couldn't get it to work with "auto".
And in this document it states all options except "auto".
https://www.cisco.com/c/en/us/td/docs/security/firepower/601/configuration/guide/fpmc-config-guide-v601/fpmc-config-guide-v601_chapter_01101011.pdf
br, Micke
Beginner
Yes.
Yes. You need to assign the IP for your port-channel. You need to provide the primary device IP as well as the secondary device IP during the configuration.
Ask the Expert- Webex Hybrid Services Solutions
