Showing results forĀ
Search instead forĀ
Did you mean:Ā
Help ASA NAT 8.3
f.mottini
Dear  all,
i have this problem.
I need to nat for navigation all private ip address that arrive to the inside interface of the ASA to a specific ip address to internet.
The inside interface have address 10.10.10.1
The IP address that arrive to the inside interface are from 10.10.10.x 10.0.10.x 172.16.0.x and 192.168.0.x. I need to nat with ip address of the outiside interface of the ASA.
ANY internal ip -----> 212.9.9.9 nat with outside ip address interface.
i perform this configuration, is this config correct?
object network out-serv
host 212.9.9.9
object-group network DM_INLINE_NETWORK_4
network-object object out-serv
nat (inside,outside1) source dynamic any interface destination static DM_INLINE_NETWORK_4 DM_INLINE_NETWORK_4
thanks  a lot regards
If you just want to restrict it for a specific internet IP, then your Nat statement is absoultely correct:
Varun Rao
Security Team,
Cisco TAC
Varun Rao
varrao
Level 10
Level 10
Your nat should just be:
and this would nat all the traffic coming from inside interface and going to internet to the outside interface of the ASA.
Varun Rao
Security Team,
Cisco TAC
Varun Rao
but if i want to restrict the nat to an exactly destination 212.9.9.9
so i want that all the inside networks are translated with the outside interface when try to contact this pubblic ip address 212.9.9.9
thanks a lot best regards
Varun Rao
Security Team,
Cisco TAC
Varun Rao
thanks a lot
regards
