Welcome to Cisco Firewalls Community
200
Beginner
help deciphering QoS config for VoIP
our VoIP provider sent us the following configuration to apply to our ASA to QoS our VoIP traffic.
Can someone break down for me what exactly it is doing?  are both instances of bandwidth in bps representative of the bandwidth I want reserved for VoIP?  Or is one supposed to represent the amount of bandwidth set aside for normal web traffic? or something else?
class-map ESI-voice
match dscp af33 cs5 ef
policy-map ESI-priority
class ESI-voice
priority
policy-map qos-shaper-general
class class-default
shape average <bandwidth in bps>
policy-map qos-realtime-shaper
class class-default
service-policy ESI-priority
service-policy qos-realtime-shaper interface outside
Thanks!
1 REPLY 1
VIP Advisor
Re: help deciphering QoS config for VoIP
Let's start with this
class class-default
shape average
*It is not used anyware so you can take it off*
Other than that ESI-priority matches traffic marked as AF33,CS5,EF and put
it in priority queue but you need to define what is the reserved priority
bandwidth in the same command.
Also very important to make sure that you don't have devices between phones
and ASA which strips marking like a switch otherwise you will never match
the policy (the switch should be configured to trust the markings using MQC
or trust command - if supported)
Then the qos-realtime-shaper shapes the traffic at x amount which should be
the link bandwidth and within that reserves traffic for voice by calling
ESI policy.
Content for Community-Ad
FusionCharts will render here
