how to allow all traffic from outside to inside on ASA 9.8(1)
hiprecy123
hello everyone  i want to allow all the trafiic coming from the subnet(192.168.10.0/24) connected to outside interface  going to the subnet(10.30.30.0/24) connected  to ninside interface
please  help me   i tried all the ways but still havent yet got the solution
currently am running ios version 9.8(1)   and  the trafiic from inside to outside is working ok
awaiting guys
6 Replies 6
bhargavdesai
Normally you should create ACL and apply the ACL on Outside interface in "IN" direction.
access-list OUTSIDE_IN extended permit ip 192.168.10.0 255.255.255.0 10.30.30.0 255.255.255.0
access-group OUTSIDE_IN in interface OUTSIDE
If you are having issue, can you send the packet tracer output so that it will give us more idea about problem.
packet-tracer input OUTSIDE tcp 192.168.10.10 80 10.30.30.10 80 detailed
### RATE ALL HELPFUL RESPONSES ###
Guys i tried that but it didnt work  does the accesslist or the command allow all the traffic including  icmp also ??
You should have ICMP inspected along with the ACLs. You can do that with below mentioned command.
"Fixup protocol icmp"
If you still having issue. please post the Packet-tracer output for ICMP.
packet-tracer input OUTSIDE icmp 192.168.10.10 8 0 10.30.30.10 detailed
To allow the return traffic for ping, you would need to either specifically allow this in the ACL on the outside interface or configure inspection of the ICMP protocol as mentioned by @bhargavdesai .
It would really be helpful to see your full running configuration (remove any public IPs, usernames and passwords) as right now we are just guessing at what might be wrong.
Please remember to select a correct answer and rate helpful posts
Would help if you told us exactly what you have tried and also provide us with a full running configuration of your ASA.
Do you have any NAT configuration between the two interfaces you want to allow traffic on?
Normally, if this is just between two private IP address spaces, then you would just allow that traffic in an access list on the outside interface.
access-list outside_access_in permit ip 192.168.10.0 255.255.255.0 10.30.30.0 255.255.255.0
access-group outside_access_in in interface outside
yeah those subnets are both private ...but thanks for yr support let me apply that and get back to you
