How to drop unsolicited packets with ZBF?
tresdodi
My goal is to make the WAN interface of my router "stealth" to unsolicited TCP incoming packets. That is so that it simply drops packets without a match in the NAT table instead of replying ICMP host unreachable. The router is behind my ISP modem and it's NATting between the LAN and WAN. I configured Zone Based Firewall (ZBF) but a scan of the WAN still sees the ports closed instead of stealth. I'd greatly appreciate any insights. This is my configuration:
class-map type inspect match-all LAN_TO_WAN_CLASS_MAP
match access-group 1
policy-map type inspect LAN_TO_WAN_POLICY
class type inspect LAN_TO_WAN_CLASS_MAP
  inspect
class class-default
  drop log
zone security LAN
zone security WAN
zone-pair security LAN_TO_WAN source LAN destination WAN
service-policy type inspect LAN_TO_WAN_POLICY
interface GigabitEthernet0/0
description WAN
ip address dhcp client-id GigabitEthernet0/0
ip nat outside
ip virtual-reassembly in
zone-member security WAN
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
description LAN
ip nat inside
zone-member security LAN
duplex auto
speed auto
ip forward-protocol nd
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit 192.168.0.0 0.0.255.255
tresdodi
The solution was to create a zone pair between the self zone and the WAN.
tresdodi
