How to enable access from outside to inside network to SQL server?
hyvonto
I am having proglem to get work from outside network to inside network. I have made nat rules etc already and giving permissson, tried use tcp and udp ports. Inside network everything is working. I have tried 1433 and 3838 ports both are working inside. What I have done is used that single port 3838 with tcp and udp on only tcp.
Is somebody have done this. If you would give help or correct command to no it right and getting work.
Config would bee 192.168.13.100 is SQL server, and port 1433 and 3838 are in sql configuration in use are working inside network.
public address xx.xx.xx.42.
Firewall is ASA
I would need to get this work asap.
Hopefully somebody can help about.
12 Replies 12
Without seeing your configuration we can not tell you what is wrong with it.  Your NAT and access-list rules might be correct but there is another NAT rule which is being hit.  But here is an example of how it would be done.
object network REAL-IP
host 10.10.10.10
object network NAT-IP
host 20.20.20.10
nat (inside,outside) source static REAL-IP NAT-IP service tcp 1433 1433
access-list outside-in extended permit tcp any host 10.10.10.10 eq 1433
access-group in interface outside
Please remember to select a correct answer and rate helpful posts
Hi, I got fallowing error message in attached files
I checked running config:
ASA Version 9.5(1)
access-list WAN-in extended permit tcp any host (inside ip) eq 1433
access-list outside-in extended permit tcp any host (inside ip) eq 1433
access-list wan-in extended permit tcp any host (inside ip) eq 1433
How I can delete these access list from config?
object network CSI-LAN host (inside ip)
object network CSI-WAN host (public ip)
interface GigabitEthernet0/0 nameif WAN
interface GigabitEthernet0/1 nameif LAN
This kind existing, should access list be this kind?
access-list WAN_access_in extended permit tcp any object SECUREMAIL eq https
To remove access list entries from the configuration in ASDM, just find the rule, select the rule and click delete at the top of the ASDM page (or just right click the rule and select delete.)
The access-group command failed because I forgot to include the name of the ACL in the command.  But if you already have an access-list in place then you do not need this command. You would just need to amend the access-list entry so it references the correct access-list.
The NAT statement failed as there is a syntax error in it.  You need to create a service object and refere to that for the service.  But it is better to do this through ASDM if you are not very comfortable with CLI.
Would somebody be kind and send command to get this work.
Now i will tried with new ASA, to get this work.
ASA Inside: 192.168.1.1
ASA Outside: 84.50.160.82 (not real address).
SQL Server: 192.168.1.106 (gw 192.168.1.1)
SQL port 1433
SQL Client would be connection to 84.50.160.82.
Current config (only ip added)
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 84.50.160.82 255.255.255.248
interface GigabitEthernet1/2
nameif inside
security-level 100
interface GigabitEthernet1/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/5
shutdown
no nameif
no security-level
no ip addres
interface GigabitEthernet1/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/7
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/8
shutdown
no nameif
no security-level
no ip address
interface Management1/1
management-only
no nameif
no security-level
no ip address
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (any,outside) dynamic interface
nat (inside,outside) after-auto source dynamic any interface
route outside 0.0.0.0 0.0.0.0 84.50.160.81 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.10-192.168.1.20 inside
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:d3557ef79fa29ea436850fa22156771e
: end
remove this NAT statement first:
no nat (any,outside) dynamic interface
Then configure this (remember to replace IPs with real IPs, you can also change the object names if you like):
object network SQL_SERVER
  host 192.168.1.10
object network SQL_PUBLIC
  host 1.2.3.4
object service TCP_SQL
  service tcp source eq 1433
nat (inside,outside) source static SQL_SERVER SQL_PUBLIC service TCP_SQL
access-list outside_access_in extended permit tcp any host 192.168.1.10 eq 1433
access-group outside_access_in in interface outside
This ip 1.2.3.4 is public address.
In this configuration isp is giving only one ip, what is givent to outside interface. In config would this 1.2.3.4 be changed to 84.50.160.82
Then in the above configuration just replace SQL_PUBLIC with the keyword interface and replace the IP address in the SQL_SERVER objcet to the required IP.
So configuration is then:
host 192.168.1.106
nat (inside,outside) source static SQL_SERVER interface service TCP_SQL
access-list outside_access_in extended permit tcp any host 192.168.1.106 eq 1433
Is this correct then?
Just an explanation on removing the dynamic NAT.  You have two dynamic NAT on in Auto NAT and the other in after-auto. so for keeping the configuration tidy I suggest removing the dynamic NAT in the Auto NAT section.
Other than that, yes, this configuration looks correct.
Hopefully last one
ERROR: % Incomplete command
Just an FYI you can use the "?" (without quotes) in CLI to see what is missing at the end of the command.
You might need to add andother TCP_SQL at the end.
nat (inside,outside) source static SQL_SERVER interface service TCP_SQL TCP_SQL
