Welcome to Cisco Firewalls Community
27341
Beginner
How to enable Cisco Anyconnect VPN through Remote Desktop
When users are trying to get connected to VPN from Remote machines. They are getting below Err. Some one could help me in fixing this issue by command line.
"VPN Establishment capability from a Remote Desktop is disabled. A VPN Connection will not be established"
Sachin M
1 ACCEPTED SOLUTION
Hi Sachin,
Hi Sachin,
By default, only local users may connect via any connect client. You would need to edit the anyconnect client profile. Please change the  WindowsVPNEstablishment parameter to "AllowRemoteUsers" instead of "LocalUsersOnly.
Please refer the below document for more information.
http://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect30/administration/guide/anyconnectadmin30/ac13vpnxmlref.html#wp1070852
Jagrati
2 REPLIES 2
Hi Sachin,
Hi Sachin,
Jagrati
Beginner
Re: Hi Sachin,
Hi Jagraaga,
After Changed to "AllowRemoteUsers" what I have to do? Please assist me as soon as possible.
Thanks & Regards,
Likith Pallela
