ICMP drooped After applying NAT between sub interfaces
MohammadKayed
Hello , I am trying to connect ASA firewall to a switch as firewall on stick
pc1 (Vlan 10) ---------
                                       switch     ----------- ASA
pc2 (Vlan 20 ) ---------
int g0/0
no ip add
int g0/0.10
vlan 10
ip add 10.10.10.1 255.255.255.240
nameif Inside_1
security 100
no shut
int g0/0.20
vlan 20
ip add 10.10.10.17 255.255.255.240
nameif Inside_2
security 100
no shut
this is my configuration when i try to ping PC1 to 2 or vise versa its works
but the issue that ( i want pc2 to see PC1 as 7.7.7.7)
#Object for PC1_NAT
Object network Ip_7
host 7.7.7.7
exit
nat (Inside_1,Inside_2) source static Ip_PC1 Ip_7
the ping fail PC1 send request to 2 , PC 2 replay to 7.7.7.7 then packet is droped only from PC2 side
i tried to ping PC1 from PC2 as ping 7.7.7.7 only request send to gateway
MohammadKayed
I have solved it thanks there was another Nat statement above
nat (any,outside) source dynamic any interface
just changed the orders.
