Welcome to Cisco Firewalls Community
430
Beginner
Inspect not working in cisco ASA
I have a cisco ASA5520 box running with IOS version8.2(5)13 where default policy map is applied globally. But I have not seen any traffic being inspected through included protocol defined under policy map.Any idea what may be the issue.All configuration seems to be ok for me.
service-policy global_policy global
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: ftp, packet 0, drop 0, reset-drop 0
      Inspect: rsh, packet 0, drop 0, reset-drop 0
      Inspect: rtsp, packet 0, drop 0, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
      Inspect: skinny , packet 0, drop 0, reset-drop 0
      Inspect: sunrpc, packet 0, drop 0, reset-drop 0
      Inspect: xdmcp, packet 0, drop 0, reset-drop 0
      Inspect: netbios, packet 0, drop 0, reset-drop 0
      Inspect: icmp error, packet 0, drop 0, reset-drop 0
      Inspect: tftp, packet 0, drop 0, reset-drop 0
      Inspect: icmp, packet 0, drop 0, reset-drop 0
      Inspect: h323 h225 _default_h323_map, packet 0, drop 0, reset-drop 0
      Inspect: dns preset_dns_map_1, packet 0, drop 0, reset-drop 0
1 REPLY 1
I'm assuming you've the service-policy global_policy global command in place, hence I can only assume that this is a bug with your present version. After all, version 8.2.5 has brought me more headaches than anything else.
Perhaps, you could try downgrading to version 8.2.4, for example. This version is alrite. You can't upgrade to version 8.3.X as this requires memory upgrade, which means money $$$
Warm regards,
Ramraj Sivagnanam Sivajanam
Content for Community-Ad
FusionCharts will render here
