inspection protocol on ASA 5510
Alaa.Jararha
dears
i have a aproblem with connection between ASA 5510 and WASS , after i am check another ASA 5520 that Support inspect WASS ,
but i want to allow inspect WASS on ASA 5510 , so how can i solve this issue plz
Alaa Jararha
5 Replies 5
Kureli Sankar
I am not sure if I understand the question.
You have a 5520 where a waas issue was solved by enabled inspect waas and you'd like to do the same thing with the 5510?
Just enable inspect waas on the 5510.  You are unable to do that?
Make sure you are running 7.2.1 or above in the ASA which is when the command was introduced.
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/i2.html#wp1723612
-KS
Dears ,
I would like to thank you for you're response but as you know we can't
enable inspect wass on ASA5510
I have 8.0 is running but I don't have inspect wass , so do you have another
soluation plz
Thank youuuuuuuuuuuuuu
alaa jararha
Alaa,
You keep referring to 'wass' is this a typo?
Are you referring to WAAS - Wide Area Application Services?
Your correct by what you have typed WASS is not supported and to be honest I have no idea what you are referring to if this is the case.
The ouput I had previously posted was from an ASA5510 so it is definitely supported.
Im not aware of any licensing restrictions for this either.
Stu
You config should look something like the following:
policy-map global_policy
class inspection_default
  inspect waas
Is this how you are trying to apply it?
Stu
stuart
Alaa,
I'm not sure what your trying but WAAS inspection is supported on the ASA5510 as of v7.2(1).
ASA(config-pmap-c)# inspect ?
mpf-policy-map-class mode commands/options:
  ctiqbe
  dcerpc
  dns
  esmtp
  ftp
  h323
  http
  icmp
  ils
  im
  ipsec-pass-thru
  mgcp
  mmp
  netbios
  pptp
  rsh
  rtsp
  sip
  skinny
  snmp
  sqlnet
  sunrpc
  tftp
  waas
  xdmcp
What version of code are you running?
I have checked through the docs also and see no restrictions on platform for WAAS.
Stu
