Inter VLAN Routing with ASA 5520 and Cat 2960
dreweharris
Hi there,
I am a complete novice at networking, but I was tasked to have an ASA 5520 do inter VLAN routing (since my shop doesn't have a layer 3 router).
As a basic setup, I am trying to have three workstations on three different VLANs communicate with each other.  The attached screenshot shows the topology.
I am unable to ping from a PC to the ASA...therefore I can't ping to other VLANs.  Any assistance would be greatly appreciated.
ROUTER CONFIG:
ciscoasa#
ciscoasa# show run
: Saved
ASA Version 8.3(1)
hostname ciscoasa
domain-name null
enable password ###### encrypted
passwd ###### encrypted
names
dns-guard
interface GigabitEthernet0/0
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
no nameif
security-level 100
ip address 10.10.1.1 255.255.255.0
interface GigabitEthernet0/1.10
vlan 10
nameif vlan10
security-level 100
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/1.20
vlan 20
nameif vlan20
security-level 100
ip address 10.10.20.1 255.255.255.0
interface GigabitEthernet0/1.30
vlan 30
nameif vlan30
security-level 100
ip address 10.10.30.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif inside
security-level 100
management-only
boot system disk0:/asa831-k8.bin
ftp mode passive
dns server-group DefaultDNS
domain-name null
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list global_access extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu vlan10 1500
mtu vlan20 1500
mtu vlan30 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
access-group global_access global
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd address 192.168.1.2-192.168.1.5 inside
dhcpd enable inside
dhcpd address 10.10.10.101-10.10.10.253 vlan10
dhcpd enable vlan10
dhcpd address 10.10.20.101-10.10.20.253 vlan20
dhcpd enable vlan20
dhcpd address 10.10.30.101-10.10.30.253 vlan30
dhcpd enable vlan30
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DD
CEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:4ad1bba72f1f51b2a47e8cacb9d3606a
: end
SWITCH CONFIG
Switch#show run
Building configuration...
Current configuration : 2543 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
no spanning-tree vlan 1
vlan internal allocation policy ascending
description Port Configured As Trunk
switchport trunk allowed vlan 1,10,20,30,1002-1005
switchport mode trunk
switchport access vlan 10
switchport mode access
switchport access vlan 20
interface GigabitEthernet0/4
switchport access vlan 30
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface Vlan1
ip address 10.10.1.2 255.255.255.0
no ip route-cache
interface Vlan10
no ip address
no ip route-cache
interface Vlan20
no ip address
no ip route-cache
interface Vlan30
no ip address
no ip route-cache
ip default-gateway 10.10.1.1
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Machine 10.10.20.101 has an issue, it is not replying to the ICMP request - check this machine for a firewall.
30 Replies 30
andrew.prince
Level 10
Level 10
post the output from the switch of:-
show int GigabitEthernet0/1 trunk
Switch#show int gi0/1 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1,10,20,30,1002-1005
Port        Vlans allowed and active in management domain
Gi0/1       1,10,20,30
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       1,10,20,30
show vlan
show interface status (capture the first 10 interfaces)
Thanks for helping, by the way...
Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/5, Gi0/6, Gi0/7, Gi0/8
                                                Gi0/9, Gi0/10, Gi0/11, Gi0/12
                                                Gi0/13, Gi0/14, Gi0/15, Gi0/16
                                                Gi0/17, Gi0/18, Gi0/19, Gi0/20
                                                Gi0/21, Gi0/22, Gi0/23, Gi0/24
                                                Gi0/25, Gi0/26, Gi0/27, Gi0/28
                                                Gi0/29, Gi0/30, Gi0/31, Gi0/32
                                                Gi0/33, Gi0/34, Gi0/35, Gi0/36
                                                Gi0/37, Gi0/38, Gi0/39, Gi0/40
                                                Gi0/41, Gi0/42, Gi0/43, Gi0/44
                                                Gi0/45, Gi0/46, Gi0/47, Gi0/48
10   public                           active    Gi0/2
20   atd                              active    Gi0/3
30   VLAN0030                         active    Gi0/4
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
Switch#show int status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/1     Port Configured As connected    trunk      a-full a-1000 10/100/1000Ba
seTX
Gi0/2                        notconnect   10           auto   auto 10/100/1000Ba
seTX
Gi0/3                        notconnect   20           auto   auto 10/100/1000Ba
seTX
Gi0/4                        notconnect   30           auto   auto 10/100/1000Ba
seTX
Gi0/5                        notconnect   1            auto   auto 10/100/1000Ba
seTX
Gi0/6                        notconnect   1            auto   auto 10/100/1000Ba
seTX
Gi0/7                        notconnect   1            auto   auto 10/100/1000Ba
seTX
Gi0/8                        notconnect   1            auto   auto 10/100/1000Ba
seTX
Gi0/9                        notconnect   1            auto   auto 10/100/1000Ba
seTX
Gi0/10                       notconnect   1            auto   auto 10/100/1000Ba
seTX
When I ran the command, no workstations were plugged in...
Sure - np
OK - looking at the below you have a physical issue, let me explain:-
Gi0/1     Port Configured As connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/2                        notconnect   10           auto   auto 10/100/1000BaseTX
Gi0/3                        notconnect   20           auto   auto 10/100/1000BaseTX
Gi0/4                        notconnect   30           auto   auto 10/100/1000BaseTX
The switch either has nothing connected to the ports, you have 3 x fault cables or the 3 devices are not powered up.
Check your physicals.
HTH>
The reason for that is that I had nothing plugged in at the time I ran the command.  When I plug in a workstation, it says "connected" for the status of the port....
Still can't ping 10.10.1.1 from the workstation.
August Ritchie
I see you grabbed a show int from the switch, but what about from the ASA?
Can you grab "sh int gi0/1"
What about pinging from the ASA, can you ping the device in vlan10 from the ASA? Before you do, issue this:
capture cap10 interface vlan10
Then ping
then issue:
show cap cap10
No problem...
ciscoasa# show int gi0/1
Interface GigabitEthernet0/1 "", is up, line protocol is up
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
        Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
        Input flow control is unsupported, output flow control is unsupported
        Available but not configured via nameif
        MAC address 5475.d0ba.46bb, MTU not set
        IP address 10.10.1.1, subnet mask 255.255.255.0
        4378 packets input, 467527 bytes, 0 no buffer
        Received 2715 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        30 L2 decode drops
        284 packets output, 25672 bytes, 0 underruns
        0 pause output, 0 resume output
        0 output errors, 0 collisions, 2 interface resets
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops, 0 tx hangs
        input queue (blocks free curr/low): hardware (255/253)
        output queue (blocks free curr/low): hardware (255/253)
Instead of vlan10, I have a laptop (10.10.20.101) plugged into the vlan20 port.
ciscoasa# capture cap10 interface vlan20
ciscoasa# ping 10.10.20.101
Sending 5, 100-byte ICMP Echos to 10.10.20.101, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
ciscoasa# show cap cap10
27 packets captured
   1: 16:33:08.777334 802.1Q vlan#20 P0 10.10.20.101.137 > 74.55.74.138.137:  ud
p 50
   2: 16:33:09.381541 802.1Q vlan#20 P0 10.10.20.101 > 10.10.20.1: icmp: echo re
quest
   3: 16:33:09.381770 802.1Q vlan#20 P0 10.10.20.1 > 10.10.20.101: icmp: echo re
ply
   4: 16:33:10.271180 802.1Q vlan#20 P0 10.10.20.101.137 > 74.55.74.138.137:  ud
p 50
   5: 16:33:10.331159 802.1Q vlan#20 P0 10.10.20.101.10368 > 10.10.20.1.8905:  u
dp 105
   6: 16:33:11.771337 802.1Q vlan#20 P0 10.10.20.101.137 > 74.55.74.138.137:  ud
p 50
   7: 16:33:14.381816 802.1Q vlan#20 P0 10.10.20.101 > 10.10.20.1: icmp: echo re
quest
   8: 16:33:14.382045 802.1Q vlan#20 P0 10.10.20.1 > 10.10.20.101: icmp: echo re
ply
   9: 16:33:15.331678 802.1Q vlan#20 P0 10.10.20.101.10369 > 10.10.20.1.8905:  u
dp 103
  10: 16:33:18.466925 802.1Q vlan#20 P0 10.10.20.1 > 10.10.20.101: icmp: echo re
quest
However, when workstation 10.10.20.101 tries to ping the ASA (10.10.1.1), "Destination host unreachable" is the message...
Drew
Well you won't be able to ping that IP address, in fact you shouldn't have an IP address on that interface at all really. Your real testing should pretty much be from host on 1 vlan to the host on the other. You won't be able to ping any IP address on the ASA except the one you are directly behind. So for 10.10.20.101 that means the only pingable ASA IP will be 10.10.20.1
That is good to know.  So here are the current symptoms...
I have three laptops plugged in...one in each vlan port.
10.10.10.101 --> Can ping 10.10.20.101, but not 10.10.30.101
10.10.20.101 --> Cannot ping either 10.10.10.101 or 10.10.30.101
10.10.30.101 --> Cannot ping 10.10.10.101, but can ping 10.10.20.101
Each laptop can ping its direct gateway on the ASA.
Hmm, can you double check the default gateway on 10.10.20.101?
also try this...
no cap cap10
capture cap20 interface vlan20
Then ping from host on vlan10 to host on vlan20
Then get the outputs of "show cap cap10" and "show cap cap20"
ciscoasa# capture cap10 interface vlan10
ciscoasa# capture cap20 interface vlan20
97 packets captured
   1: 17:32:32.541262 802.1Q vlan#10 P0 10.10.10.101.2461 > 10.10.10.1.8905:  ud
p 96
   2: 17:32:36.741294 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
   3: 17:32:36.741523 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
   4: 17:32:37.539217 802.1Q vlan#10 P0 10.10.10.101.2462 > 10.10.10.1.8905:  ud
p 98
   5: 17:32:39.104914 802.1Q vlan#10 P0 10.10.10.101.2463 > 10.12.5.64.8906:  ud
p 95
   6: 17:32:41.738914 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
   7: 17:32:41.739143 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
   8: 17:32:42.544023 802.1Q vlan#10 P0 10.10.10.101.2464 > 10.10.10.1.8905:  ud
p 93
   9: 17:32:46.747352 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  10: 17:32:46.747580 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  11: 17:32:47.546633 802.1Q vlan#10 P0 10.10.10.101.2465 > 10.10.10.1.8905:  ud
p 98
  12: 17:32:51.739921 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  13: 17:32:51.740150 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  14: 17:32:52.544100 802.1Q vlan#10 P0 10.10.10.101.2466 > 10.10.10.1.8905:  ud
p 98
  15: 17:32:56.741859 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  16: 17:32:56.742088 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  17: 17:32:57.547396 802.1Q vlan#10 P0 10.10.10.101.2467 > 10.10.10.1.8905:  ud
p 98
  18: 17:33:01.742728 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  19: 17:33:01.742957 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  20: 17:33:02.547609 802.1Q vlan#10 P0 10.10.10.101.2468 > 10.10.10.1.8905:  ud
p 97
  21: 17:33:06.742774 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  22: 17:33:06.743018 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  23: 17:33:07.543337 802.1Q vlan#10 P0 10.10.10.101.2469 > 10.10.10.1.8905:  ud
p 93
  24: 17:33:10.375514 802.1Q vlan#10 P0 10.10.10.101.137 > 10.10.10.255.137:  ud
p 50
  25: 17:33:11.114679 802.1Q vlan#10 P0 10.10.10.101.137 > 10.10.10.255.137:  ud
p 50
  26: 17:33:11.742728 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  27: 17:33:11.742957 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  28: 17:33:11.864731 802.1Q vlan#10 P0 10.10.10.101.137 > 10.10.10.255.137:  ud
p 50
  29: 17:33:12.546266 802.1Q vlan#10 P0 10.10.10.101.2470 > 10.10.10.1.8905:  ud
p 98
  30: 17:33:16.746497 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  31: 17:33:16.746726 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  32: 17:33:17.548403 802.1Q vlan#10 P0 10.10.10.101.2471 > 10.10.10.1.8905:  ud
p 97
  33: 17:33:21.744880 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  34: 17:33:21.745109 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  35: 17:33:22.545351 802.1Q vlan#10 P0 10.10.10.101.2472 > 10.10.10.1.8905:  ud
p 95
  36: 17:33:23.785558 802.1Q vlan#10 P0 10.10.10.101.137 > 10.10.10.255.137:  ud
p 50
  37: 17:33:24.522464 802.1Q vlan#10 P0 10.10.10.101.137 > 10.10.10.255.137:  ud
p 50
  38: 17:33:25.272568 802.1Q vlan#10 P0 10.10.10.101.137 > 10.10.10.255.137:  ud
p 50
  39: 17:33:26.744926 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  40: 17:33:26.745154 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  41: 17:33:27.548708 802.1Q vlan#10 P0 10.10.10.101.2473 > 10.10.10.1.8905:  ud
p 96
  42: 17:33:31.749625 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  43: 17:33:31.749854 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  44: 17:33:32.550096 802.1Q vlan#10 P0 10.10.10.101.2474 > 10.10.10.1.8905:  ud
p 97
  45: 17:33:36.748343 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  46: 17:33:36.748572 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  47: 17:33:37.546251 802.1Q vlan#10 P0 10.10.10.101.2475 > 10.10.10.1.8905:  ud
p 95
  48: 17:33:41.745566 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  49: 17:33:41.745795 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  50: 17:33:42.547975 802.1Q vlan#10 P0 10.10.10.101.2476 > 10.10.10.1.8905:  ud
p 97
  51: 17:33:46.747855 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  52: 17:33:46.748084 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  53: 17:33:47.548403 802.1Q vlan#10 P0 10.10.10.101.2477 > 10.10.10.1.8905:  ud
p 94
  54: 17:33:51.747718 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  55: 17:33:51.747931 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  56: 17:33:52.547670 802.1Q vlan#10 P0 10.10.10.101.2478 > 10.10.10.1.8905:  ud
p 97
  57: 17:33:54.134239 802.1Q vlan#10 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  58: 17:33:56.750678 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  59: 17:33:56.750891 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  60: 17:33:57.563035 802.1Q vlan#10 P0 10.10.10.101.2479 > 10.10.10.1.8905:  ud
p 97
  61: 17:33:59.245272 802.1Q vlan#10 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  62: 17:34:01.752188 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  63: 17:34:01.752402 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  64: 17:34:01.995737 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 49
  65: 17:34:01.995813 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 34
  66: 17:34:01.995950 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 49
  67: 17:34:01.996011 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 34
  68: 17:34:01.996118 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 49
  69: 17:34:01.996179 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 34
  70: 17:34:02.551836 802.1Q vlan#10 P0 10.10.10.101.2480 > 10.10.10.1.8905:  ud
p 98
  71: 17:34:03.011306 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 49
  72: 17:34:03.011367 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 34
  73: 17:34:03.011443 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 49
  74: 17:34:03.011489 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 34
  75: 17:34:03.011550 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 49
  76: 17:34:03.011596 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 34
  77: 17:34:04.027037 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 49
  78: 17:34:04.027082 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 34
  79: 17:34:04.027174 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 49
  80: 17:34:04.027250 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 34
  81: 17:34:04.027311 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 49
  82: 17:34:04.027357 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 34
  83: 17:34:04.745811 802.1Q vlan#10 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  84: 17:34:06.058514 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 49
  85: 17:34:06.058605 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.23.427:  u
dp 34
  86: 17:34:06.058651 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 49
  87: 17:34:06.058712 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.16.22.427:  u
dp 34
  88: 17:34:06.058758 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 49
  89: 17:34:06.058819 802.1Q vlan#10 P0 10.10.10.101.2263 > 156.80.200.40.427:
udp 34
  90: 17:34:06.750907 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  91: 17:34:06.751151 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  92: 17:34:07.552751 802.1Q vlan#10 P0 10.10.10.101.2481 > 10.10.10.1.8905:  ud
p 96
  93: 17:34:11.752082 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  94: 17:34:11.752326 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  95: 17:34:12.553392 802.1Q vlan#10 P0 10.10.10.101.2482 > 10.10.10.1.8905:  ud
p 96
  96: 17:34:16.755438 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
  97: 17:34:16.755682 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
  98: 17:34:17.554811 802.1Q vlan#10 P0 10.10.10.101.2483 > 10.10.10.1.8905:  ud
p 97
  99: 17:34:21.751303 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
100: 17:34:21.751563 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
101: 17:34:22.552034 802.1Q vlan#10 P0 10.10.10.101.2484 > 10.10.10.1.8905:  ud
p 95
102: 17:34:26.753989 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
103: 17:34:26.754218 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
104: 17:34:27.560334 802.1Q vlan#10 P0 10.10.10.101.2485 > 10.10.10.1.8905:  ud
p 98
105: 17:34:31.755499 802.1Q vlan#10 P0 10.10.10.101 > 10.10.10.1: icmp: echo re
quest
106: 17:34:31.755728 802.1Q vlan#10 P0 10.10.10.1 > 10.10.10.101: icmp: echo re
ply
107: 17:34:32.563950 802.1Q vlan#10 P0 10.10.10.101.2486 > 10.10.10.1.8905:  ud
p 95
107 packets shown
ciscoasa# show cap cap20
92 packets captured
   1: 17:26:53.653378 802.1Q vlan#20 P0 10.10.20.101.1187 > 216.49.94.13.80: S 8
20343450:820343450(0) win 65535
   2: 17:27:12.019133 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
   3: 17:27:17.214481 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
   4: 17:27:55.593688 802.1Q vlan#20 P0 10.10.20.101.1188 > 216.49.94.13.80: S 1
499891746:1499891746(0) win 65535
   5: 17:27:58.555284 802.1Q vlan#20 P0 10.10.20.101.1188 > 216.49.94.13.80: S 1
   6: 17:28:04.564790 802.1Q vlan#20 P0 10.10.20.101.1188 > 216.49.94.13.80: S 1
   7: 17:29:06.504856 802.1Q vlan#20 P0 arp who-has 10.10.20.1 tell 10.10.20.101
   8: 17:29:06.504917 802.1Q vlan#20 P0 arp reply 10.10.20.1 is-at 54:75:d0:ba:4
6:bb
   9: 17:29:06.505222 802.1Q vlan#20 P0 10.10.20.101.1189 > 216.49.94.13.80: S 4
7080594:47080594(0) win 65535
  10: 17:29:09.467032 802.1Q vlan#20 P0 10.10.20.101.1189 > 216.49.94.13.80: S 4
  11: 17:29:15.476537 802.1Q vlan#20 P0 10.10.20.101.1189 > 216.49.94.13.80: S 4
  12: 17:30:17.417245 802.1Q vlan#20 P0 10.10.20.101.1190 > 216.49.94.13.80: S 1
445997597:1445997597(0) win 65535
  13: 17:30:18.156043 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  14: 17:30:20.378688 802.1Q vlan#20 P0 10.10.20.101.1190 > 216.49.94.13.80: S 1
  15: 17:30:23.220356 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  16: 17:30:26.388102 802.1Q vlan#20 P0 10.10.20.101.1190 > 216.49.94.13.80: S 1
  17: 17:30:28.721047 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  18: 17:30:34.222507 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  19: 17:33:43.156928 802.1Q vlan#20 P0 arp who-has 10.10.20.101 tell 10.10.20.1
01
  20: 17:33:44.187002 802.1Q vlan#20 P0 arp who-has 10.10.20.1 tell 10.10.20.101
  21: 17:33:44.187047 802.1Q vlan#20 P0 arp reply 10.10.20.1 is-at 54:75:d0:ba:4
6:bb
  22: 17:33:44.187261 802.1Q vlan#20 P0 10.10.20.101 > 10.10.20.1: icmp: echo re
quest
  23: 17:33:44.187520 802.1Q vlan#20 P0 10.10.20.1 > 10.10.20.101: icmp: echo re
ply
  24: 17:33:44.239016 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  25: 17:33:44.327360 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.26.53:
udp 34
  26: 17:33:44.989740 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  27: 17:33:45.150611 802.1Q vlan#20 P0 10.10.20.101.6646 > 10.10.20.255.6646:
udp 236
  28: 17:33:45.331312 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.27.53:
udp 34
  29: 17:33:45.740943 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  30: 17:33:46.331892 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.26.53:
udp 34
  31: 17:33:46.492131 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  32: 17:33:47.243502 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  33: 17:33:47.994501 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  34: 17:33:48.335050 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.26.53:
udp 34
  35: 17:33:48.335141 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.27.53:
udp 34
  36: 17:33:48.745658 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  37: 17:33:49.496861 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  38: 17:33:50.248812 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  39: 17:33:50.249300 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  40: 17:33:50.999170 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  41: 17:33:50.999246 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  42: 17:33:51.750342 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  43: 17:33:51.750418 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  44: 17:33:52.341336 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.26.53:
udp 34
  45: 17:33:52.341474 802.1Q vlan#20 P0 10.10.20.101.53835 > 208.231.55.27.53:
udp 34
  46: 17:33:52.501576 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  47: 17:33:52.501652 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  48: 17:33:53.254183 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 174
  49: 17:33:53.254320 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 204
  50: 17:33:54.134361 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  51: 17:33:54.755118 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 174
  52: 17:33:54.823535 802.1Q vlan#20 P0 10.120.2.198.1261 > 161.69.12.13.443: R
250934743:250934743(0) ack 2427374744 win 0
  53: 17:33:54.823901 802.1Q vlan#20 P0 10.120.2.198.1262 > 161.69.12.13.443: R
3313764765:3313764765(0) ack 1397588942 win 0
  54: 17:33:54.824618 802.1Q vlan#20 P0 10.10.20.101.1269 > 161.69.12.13.443: S
2860571026:2860571026(0) win 65535
  55: 17:33:56.257448 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 174
  56: 17:33:57.759833 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 174
  57: 17:33:57.779729 802.1Q vlan#20 P0 10.10.20.101.1269 > 161.69.12.13.443: S
  58: 17:33:59.245394 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  59: 17:33:59.262178 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 186
  60: 17:34:00.263780 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 186
  61: 17:34:01.265382 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 186
  62: 17:34:02.266908 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 186
  63: 17:34:03.268540 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  64: 17:34:03.789189 802.1Q vlan#20 P0 10.10.20.101.1269 > 161.69.12.13.443: S
  65: 17:34:04.019591 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  66: 17:34:04.745933 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo
request
  67: 17:34:04.770757 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  68: 17:34:05.521991 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  69: 17:34:06.273209 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  70: 17:34:07.024367 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  71: 17:34:07.775518 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  72: 17:34:08.526706 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 68
  73: 17:34:09.277939 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 174
  74: 17:34:09.278061 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 174
  75: 17:34:09.278702 802.1Q vlan#20 P0 10.10.20.101.138 > 10.10.20.255.138:  ud
p 204
  76: 17:34:15.810489 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.26.53:
udp 31
  77: 17:34:16.809726 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.27.53:
udp 31
  78: 17:34:17.811222 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.26.53:
udp 31
  79: 17:34:19.814349 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.26.53:
udp 31
  80: 17:34:19.814380 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.27.53:
udp 31
  81: 17:34:23.820682 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.26.53:
udp 31
  82: 17:34:23.820788 802.1Q vlan#20 P0 10.10.20.101.49796 > 208.231.55.27.53:
udp 31
  83: 17:34:30.822924 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 50
  84: 17:34:31.572892 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 50
  85: 17:34:32.324079 802.1Q vlan#20 P0 10.10.20.101.137 > 10.10.20.255.137:  ud
p 50
  86: 17:34:33.083079 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.26.53:
udp 44
  87: 17:34:34.077007 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.27.53:
udp 44
  88: 17:34:35.078639 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.26.53:
udp 44
  89: 17:34:37.081584 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.26.53:
udp 44
  90: 17:34:37.081706 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.27.53:
udp 44
  91: 17:34:41.087809 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.26.53:
udp 44
  92: 17:34:41.087840 802.1Q vlan#20 P0 10.10.20.101.61089 > 208.231.55.27.53:
udp 44
92 packets shown
I see a few of them go all the way through, but no echo replies from 10.10.20.101
Does this have a windows firewall on?
Can you install wireshark on that PC and see if you are receiving any icmps?
From vlan 10 cap
57: 17:33:54.134239 802.1Q vlan#10 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
61: 17:33:59.245272 802.1Q vlan#10 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
83: 17:34:04.745811 802.1Q vlan#10 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
From vlan 20 cap
2: 17:27:12.019133 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
3: 17:27:17.214481 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
13: 17:30:18.156043 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
15: 17:30:23.220356 802.1Q vlan#20 P0 10.10.10.101 > 10.10.20.101: icmp: echo request
see attached screenshot (from 10.10.20.101 wireshark).  i did a ping from 10.10.10.101 to ...20.101 and used wireshark on ...20.101 to do capture.
