Welcome to Cisco Firewalls Community
209
Beginner
IOS CBAC is dropping already permitted packets. is it possible to exclude /32 IP from CBAC inspection?
Hello.
My router x.x.x.x utilizing CBAC time to time drops packets from y.y.y.y to x.x.x.x
x.x.x.x is writes following in log file:
Nov 7 01:01:47 gate.sta17.net 998275: Nov 7 01:01:46: %FW-6-DROP_PKT: Dropping tcp session x.x.x.x:55802 y.y.y.y:443 due to RST inside current window with ip ident 24576 tcpflags 0x5014 seq.no 2217371408 ack 3597684402
gate router config looks like:
gate(config)#do sh runn | s ip inspect
ip inspect log drop-pkt
ip inspect audit-trail
ip inspect max-incomplete high 10000
ip inspect max-incomplete low 8900
ip inspect one-minute low 8900
ip inspect one-minute high 10000
ip inspect udp idle-time 360
ip inspect dns-timeout 20
ip inspect tcp idle-time 7200
ip inspect tcp finwait-time 32
ip inspect tcp max-incomplete host 800 block-time 0
ip inspect tcp reassembly queue length 1024
ip inspect tcp reassembly timeout 120
ip inspect tcp reassembly memory limit 512000
ip inspect tcp reassembly alarm on
ip inspect name DIAL_OUT ftp alert on audit-trail off timeout 120
ip inspect name DIAL_OUT router alert on audit-trail off timeout 120
ip inspect name DIAL_OUT tcp alert on audit-trail off timeout 120
ip inspect name DIAL_OUT udp alert on audit-trail off timeout 120
ip inspect name DIAL_OUT rtsp alert on audit-trail off timeout 120
where interface gi8 is outside one connected to ISP:
gate(config)#do sh ip inspec inter
Interface Configuration
Interface GigabitEthernet8
Inbound inspection rule is not set
Outgoing inspection rule is DIAL_OUT
ftp alert is on audit-trail is off timeout 120
router alert is on audit-trail is off timeout 120
tcp alert is on audit-trail is off timeout 120
udp alert is on audit-trail is off timeout 120
rtsp alert is on audit-trail is off timeout 120
Inbound access list is DI_IN
Outgoing access list is not set
gate(config)#
Could you suggest what wrong with config above? Also please suggest how to exclude IP y.y.y.y from x.x.x.x's CBAC inspection?
Thank you.
Thank you.
Everyone's tags (1)
Content for Community-Ad
FusionCharts will render here
