IPTABLES to ASA Conversion
danielnunes
Hi Folks,
does anyone knows about how can I convert a script from IPTABLES to Cisco ASA?
thanks a lot
5 Replies 5
Panos Kampanakis
Unfortunately, there is no way of automatically migrating the iptabes. So you would need to do it manually or write a script to do it. A rule like
route add  -net 192.168.10.0  netmask 255.255.255.0 gw XXX.XXX.XXX.XXX dev eth1
would be translated to
route 192.168.10.0 255.255.255.0 XXX.XXX.XXX.XXX
on the firewall.
I hope it helps.
PK
Ok Kampana,
thanks for your attention.
I guess that I'll be work to do!!!
My Iptables configuration have for about 9000 lines.
I could to do a script to translate DNAT configuration but there are many differents forms from Access-list and it's difficult
to make a script for all.
8-) hehehe it's too hard!!!
thanks a lot friend!!
Yeah, I understand.
With 9K of rules, I believe you will need a script, even though it will take some time to do it. and then you might also share it in the community for other that might need it in the future
Please rate helpful posts.
Rgs,
PK
Kampana,
you are right, I'll take some take to do it, if i discover any way or script to optimize that task I'll be share with everybody.
thank a lot
see you
Folks,
does anyone help me about a sintaxe used by IPTABLES?
What's this command means?
A FORWARD -i vlan227 -j CTG-to-WAN
-A FORWARD -i eth2 -j CTG-to-WAN
-A FORWARD -d 12.10.1.0/255.255.255.0 -i eth1 -j MTBrazil-to-SN
-A FORWARD -j PCBrazil
thanks
