Welcome to Firewalls
16032
L2 decode drops
Does increasing "L2 decode drops" counter means faulty cable ? ASA (802.1q trunk) connects with 3560.
Interface Ethernet0/1 "", is up, line protocol is up
Hardware is i82546GB rev03, BW 100 Mbps, DLY 100 usec
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Available but not configured via nameif
MAC address 0021.a09a.de9f, MTU not set
IP address unassigned
59189 packets input, 13303462 bytes, 0 no buffer
Received 9951 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
13319 L2 decode drops
41659 packets output, 5683701 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 late collisions, 2 deferred
0 input reset drops, 0 output reset drops, 0 tx hangs
input queue (blocks free curr/low): hardware (255/248)
output queue (blocks free curr/low): hardware (255/248)
FastEthernet0/18 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0019.5660.1194 (bia 0019.5660.1194)
Description: asa-1-75broad(e0/1)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 18000 bits/sec, 17 packets/sec
5 minute output rate 36000 bits/sec, 35 packets/sec
87687460 packets input, 1495683997 bytes, 0 no buffer
Received 1901447 broadcasts (0 multicast)
1 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 1901389 multicast, 0 pause input
243267167 packets output, 1465350456 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
1 ACCEPTED SOLUTION
Participant
Re: L2 decode drops
Not necessarily a faulty cable. Could be traffic on VLANs that the ASA does not have configured. Since you are connected to a switch, there may be PVST spanning tree running on VLANs even though nothing is routed to the ASA.
Use the "allowed vlan" switchport subcommand on the 3560 to black output packets on unknown VLAN IDs. Note with some STP implementations there will always be STP packets going out untagged.
If you are positive nobody is going to accidentally create a packet loop some years down the road when the ASA is removed from that switchport, then you may also want to consider "spanning-tree bpdufilter enable" on the 3560 port.
1 REPLY
Participant
Re: L2 decode drops
Webcast-ISE Deployment and Best Practices
