Welcome to Cisco Firewalls Community
118
Beginner
Limiting outbound traffic to Cisco VPN clients/Users
I want to limit/filter/drop traffics that will be initiated from the inside of my network(behind the firewall) heading to Cisco VPN tunnel network/users, so basically I want always the Cisco vpn users to have access to behind(Inside interface) the firewall resources, not the inside to them, basically there would be a flow that's being initiated from Cisco VPN client address space, not the opposite.
I assigned a range of 192.168.10.x/24 for Cisco VPN clients, they are accessing the subnet 172.16.1.x/24 which is behind the firewall, how can I drop connections that wanna be initiated from 172.16.1.x/24? if I use an access list it drops even flows that are started from outside inward on their way back.
thank you so much
1 ACCEPTED SOLUTION
VIP Advocate
Re: Limiting outbound traffic to Cisco VPN clients/Users
You can use VPN filtering for this.
access-list AC-VPN-FILTER extended permit ip 172.16.1.0 255.255.255.0 192.168.10.0 255.255.255.0
group-policy AC-GrpPolicy internal
group-policy AC-GrpPolicy attributes
  vpn-filter value AC-VPN-FILTER
Please remember to rate and select a correct answer
1 REPLY 1
VIP Advocate
