Welcome to Cisco Firewalls Community
238
Limiting per-client traffic but allowing burst
Hi all,
On an ASA 5505, is there a way to limit the bandwidth per user unless there is little activity, which would then allow the user more bandwidth.
For instance, if I have a 100mb internet link, and give all connections a guaranteed 10mb, could it be configured to allow a user to use most of the 100mb in times of little use ?
Thanks in advance
1 ACCEPTED SOLUTION
VIP Advisor
Re: Limiting per-client traffic but allowing burst
is the users are remote VPN or Local Lan users. since we do not know the requirement clearly.
here  is my suggestions links for your reference to achive this.
http://blog.danmassey.net/?p=812
https://community.cisco.com/t5/firewalls/traffic-rate-limiting-on-cisco-asa-5510/td-p/1557033
https://www.petenetlive.com/KB/Article/0001001
BB
*** Rate All Helpful Responses ***
4 REPLIES 4
VIP Advisor
BB
The users will be LAN Users
VIP Advisor
check the example documents to help you, if you stuck any where.. please post the config and elaborate the issue, so we can asists better.
BB
The petenetlive article is perfect
Essentially, it's all about "police output xxxxxxx yyyyyyy"
Many thanks
